Z06Seal Posted February 28, 2014 Share Posted February 28, 2014 Getting ready to buy my stuff to get ready for my rinseless wash. Curious for waterless washing, if 32oz is sufficient for one car, or should I get the 64oz instead? it will be for regular sized cars (Q50, Volt, Corvette). I do see a Grand Cherokee in our future, for future proofing. lol Link to comment Share on other sites More sharing options...
0 SYMAWD Posted February 28, 2014 Share Posted February 28, 2014 32oz should be enough for one car. Possibly two if depending on the size. However, a rinseless wash is safer than a waterless wash. WW is best suited for dust removal more than dirt removal. Link to comment Share on other sites More sharing options...
0 Z06Seal Posted February 28, 2014 Author Share Posted February 28, 2014 Right, I understand that. I'm going to attempt the Gary Dean method with 10+ plush MF towels in a 5 gallon bucket. Instead of using one or two MF towels, cleaning it in the grit guard, and re-using it, I will just keep changing towels for each panel then wash them all when done. But I am getting the pump spray bottle for in between washes. My car could have benefited from a waterless wash today. Link to comment Share on other sites More sharing options...
0 GerryC Posted February 28, 2014 Share Posted February 28, 2014 I believe I have done my entire G8 with less than one 16 oz bottle, but it depends on the vehicle size and the amount/type of dirt that you are trying to remove. I only had very light environmental film from sitting outside overnight after a pre-show detail. A 32oz bottle should be plenty, unless you plan on doing multiple cars in one session, then opt for a larger one. Link to comment Share on other sites More sharing options...
0 Z06Seal Posted February 28, 2014 Author Share Posted February 28, 2014 I believe I have done my entire G8 with less than one 16 oz bottle, but it depends on the vehicle size and the amount/type of dirt that you are trying to remove. I only had very light environmental film from sitting outside overnight after a pre-show detail. A 32oz bottle should be plenty, unless you plan on doing multiple cars in one session, then opt for a larger one. one car is enough for me per week 32oz it is then. Glad I didn't order the 64. Thanks! Link to comment Share on other sites More sharing options...
0 Gen9Rolla Posted February 28, 2014 Share Posted February 28, 2014 32 oz should be more than plenty. Also, I can't see a 64oz bottle being very pleasant to work with and carry around Link to comment Share on other sites More sharing options...
0 mc2hill Posted February 28, 2014 Share Posted February 28, 2014 Getting ready to buy my stuff to get ready for my rinseless wash. Curious for waterless washing, if 32oz is sufficient for one car, or should I get the 64oz instead? it will be for regular sized cars (Q50, Volt, Corvette). I do see a Grand Cherokee in our future, for future proofing. lol I am a little confused on the question you are asking about the Waterless Car Wash. If you have Adam's Rinseless Wash, then you can mix that up at the waterless wash ratio (1-2 oz of Rinseless to 32 oz. of water) and not use the Waterless Car Wash. Or maybe that is the question you were asking - how much Rinseless should I mix up for this (32 oz. should be fine). The 'multi towels in a bucket/ Garry Dean' rinseless method still uses the same 1 oz to 2.5 gal. ratio as any other rinseless method. You can put some of this mixture in a spray or pump-up container for pre-treating any 'bad' spots. Sorry if that sounded 'preachy', but i wanted to be clear on what you were asking if someone else came along to do the same thing. Link to comment Share on other sites More sharing options...
0 Z06Seal Posted February 28, 2014 Author Share Posted February 28, 2014 I am a little confused on the question you are asking about the Waterless Car Wash. If you have Adam's Rinseless Wash, then you can mix that up at the waterless wash ratio (1-2 oz of Rinseless to 32 oz. of water) and not use the Waterless Car Wash. Or maybe that is the question you were asking - how much Rinseless should I mix up for this (32 oz. should be fine). The 'multi towels in a bucket/ Garry Dean' rinseless method still uses the same 1 oz to 2.5 gal. ratio as any other rinseless method. You can put some of this mixture in a spray or pump-up container for pre-treating any 'bad' spots. Sorry if that sounded 'preachy', but i wanted to be clear on what you were asking if someone else came along to do the same thing. My question was if 32oz spray bottle will be enough to do a car (waterless method). I know I will put 2oz of rinseless wash product in it. My question was if the total mixture will be enough to do a car rinseless is another story. that has nothing to do with the spray bottle:) Link to comment Share on other sites More sharing options...
0 mc2hill Posted February 28, 2014 Share Posted February 28, 2014 My question was if 32oz spray bottle will be enough to do a car (waterless method). I know I will put 2oz of rinseless wash product in it. My question was if the total mixture will be enough to do a car rinseless is another story. that has nothing to do with the spray bottle:) Ahhh, just spraying off the pollen! Then, yes, as the others said, 32 oz. should be fine. Once I had empty Adam's gallon containers I started mixing up my 'pre-mix' stuff in those. I have a 'pre-mixed' gallon of Car Wash Shampoo (1 oz. soap to 2 gallons water) that I use for 'maintained' wheels and for pre-treating, a gallon of 'foam gun ready' Car Wash Soap (6oz soap to 32 oz. water) - http://www.adamsforums.com/topic/17377-always-ready-foaming-solution/, and a 1/2 gallon pump up sprayer with Rinseless wash at wash strength for pre-treating. For all but the Foam solution I just refill my gallons with a couple of Solo cups dips in to the already mixed wash bucket before I start on the car.. Link to comment Share on other sites More sharing options...
0 Adam Posted February 28, 2014 Share Posted February 28, 2014 You really will need a few hundred gallons..... Link to comment Share on other sites More sharing options...
0 Tim Posted February 28, 2014 Share Posted February 28, 2014 Getting ready to buy my stuff to get ready for my rinseless wash. Curious for waterless washing, if 32oz is sufficient for one car, or should I get the 64oz instead? it will be for regular sized cars (Q50, Volt, Corvette). I do see a Grand Cherokee in our future, for future proofing. lol Glad to see another Volt and Vette owner here. (But my wife has a Camaro, not aQ50) Link to comment Share on other sites More sharing options...
Z06Seal
10 answers to this question
