KBsToy Posted April 8, 2014 Share Posted April 8, 2014 Am I doing something wrong when applying VRT ?? I applied some to my window trim and engine cover . When i went to rinse off area the VRT seemed to run. Any help or ideas ?? Thanks ken MeatsmeadsWab 1 Link to comment Share on other sites More sharing options...
0 2quikta Posted April 8, 2014 Share Posted April 8, 2014 Why are you rinsing it? Should just be wiped on and left. I guess you could also just be washing these areas after application, but I apply vrt when I'm done Link to comment Share on other sites More sharing options...
0 DaveVY Posted April 8, 2014 Share Posted April 8, 2014 (edited) Different plastics will hold the VRT better than others but it sounds like you had too much on there. Apply very very small amount. On some plastics or trim rubber materials you need to come back with a dry clean microfiber and wipe it down to remove the excess that the plastic won't hold. Edited April 8, 2014 by DaveVY Team Adam's and Chewy 2 Link to comment Share on other sites More sharing options...
0 Chewy Posted April 8, 2014 Share Posted April 8, 2014 Dave is right! Less is MORE!!! Apply, let sit, then level off with a MF towel. Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted April 8, 2014 Share Posted April 8, 2014 I had streaks and runs down the sides of my truck when I first started using SVRT as well. Make sure the trim is clean and free of any prior products and its already been said but let it sit then wipe with a dry microfiber and your trim will be looking great. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted April 8, 2014 Share Posted April 8, 2014 You have to really clean the trim off well with APC first. Take an all purpose MF and literally spray the whole trim with APC like you are spraying the tire, then wipe it off with the MF towel as you "scrub it" off. Give a couple mins to dry and apply a SMALL amount of VRT, work it in with an MF applicator or foam block or similar applicator. It's not applying leather conditioner or wax here, you're applying just enough to let it get into the pores of the plastic, there should be none left on the surface when done. GerryC 1 Link to comment Share on other sites More sharing options...
0 GerryC Posted April 8, 2014 Share Posted April 8, 2014 If you are applying SVRT to hard plastics, you need very little product to do so. Sometimes, you can even dress hard plastics with just the residual product still in the applicator. Hard plastics won't absorb SVRT the same way soft rubber (weatherstrip, tires, etc) does. And like others have said, make sure the surface is clean before dressing. Link to comment Share on other sites More sharing options...
0 KBsToy Posted April 8, 2014 Author Share Posted April 8, 2014 AGAIN THANKS for info, will use less next time Team Adam's 1 Link to comment Share on other sites More sharing options...
0 KBsToy Posted April 8, 2014 Author Share Posted April 8, 2014 Why are you rinsing it? Should just be wiped on and left. I guess you could also just be washing these areas after application, but I apply vrt when I'm done Thats what I was doing, rinsing down car Link to comment Share on other sites More sharing options...
0 Team Adam's Posted April 8, 2014 Share Posted April 8, 2014 Over-use of SVRT is a very common problem, and it definitely sounds like the case here Ken.Be sure to clean the surface first, go very light with the application, and for added insurance, do a quick wipe down with a utility towel to remove any excess that hasn't absorbed into the trim. KBsToy 1 Link to comment Share on other sites More sharing options...
KBsToy
Thanks
ken
9 answers to this question
