Raptor Posted May 11, 2014 Share Posted May 11, 2014 (edited) Just wondering if I can machine seal and butter wax my truck in the sun mid 70's? Edited May 11, 2014 by Raptor Link to comment Share on other sites More sharing options...
0 stirthepot Posted May 11, 2014 Share Posted May 11, 2014 yes, but i would recommend working in sections. apply to a few panels and then remove. those two products remove very easily so sun shouldn't be a problem but i would avoid doing the whole car at once. just my opinion. Link to comment Share on other sites More sharing options...
0 Kingsford Posted May 11, 2014 Share Posted May 11, 2014 You can but you shouldn't. Paint should typically be cool when applying Glazes and Waxes. It helps adhere better and dry more evenly and less rapid. I would only do this if you absolutely had no choice. I agree with Eric, if you do apply in the sun, work 1 panel at a time. Link to comment Share on other sites More sharing options...
0 Adam Posted May 11, 2014 Share Posted May 11, 2014 yes, but i would recommend working in sections. apply to a few panels and then remove. those two products remove very easily so sun shouldn't be a problem but i would avoid doing the whole car at once. just my opinion. Eric is right! stirthepot 1 Link to comment Share on other sites More sharing options...
0 GerryC Posted May 11, 2014 Share Posted May 11, 2014 If you feel the panels are going to be too hot, you can fill an empty spray bottle with distilled water and put it in the fridge before you start washing. Then when you are ready to apply your wax, use the cold water to cool the panel down. Spray, wipe dry with a separate towel, then apply your wax as normal. Kingsford, 378 Pete and JHL88 3 Link to comment Share on other sites More sharing options...
0 Gen9Rolla Posted May 11, 2014 Share Posted May 11, 2014 If you feel the panels are going to be too hot, you can fill an empty spray bottle with distilled water and put it in the fridge before you start washing. Then when you are ready to apply your wax, use the cold water to cool the panel down. Spray, wipe dry with a separate towel, then apply your wax as normal. Never would've thought of that. Good tip Link to comment Share on other sites More sharing options...
0 goheels Posted May 12, 2014 Share Posted May 12, 2014 I would recommend staying out of the sun. I would be worried about any kind of dust, pollen or debris falling on my car when working outside. The last thing you want to do is grind that stuff in the paint by machine or hand. But, I understand that not everyone has a garage to work in. Work one section at a time and don't let the polishes, etc linger too long on hot paint. Link to comment Share on other sites More sharing options...
0 Will_Cog Posted May 12, 2014 Share Posted May 12, 2014 (edited) I did this in the sun yesterday (almost the same steps but I added Glaze before the wax), machine seal, glaze and then butter wax. I think it turned out awesome! Edited May 12, 2014 by Will_Cog ArmyAcadia09, The Guz and Team Adam's 3 Link to comment Share on other sites More sharing options...
Raptor
Edited by RaptorLink to comment
