Porter cable and 4" microfiber pads
Fit08
3 answers to this question
I have not tried the 4" microfiber pads with the PC, but I have used the 7" and they do cut better than the foam, so I would imagine the 4" hold the same advantage. I would stick with speed 5, you just don't ned to use as much pressure with the smaller pads, since the power is concentrated in a smaller area.
PC and 4" MF cutting pads are great for small area correction power.  x2 on what Gerry said above me, speed 5-6 on the PC with moderate pressure on the head of the polisher will give you great correction ability, you'll be impressed!
i have my PC set up with a 3" backing plate for permanent 4" pad duty and use a newer machine for 6.5" pad duty.
