So I was detailing a buddies 2003 Topaz Blue Metallic M3 this past Saturday which I had a strange issue happen to me with Quick Sealant. it was about 70ish degrees out and mostly cloudy while I was doing the car. Maybe a little more humid then average humidity but nothing crazy
I stripped the car with Adams Car shampoo, some, Dawn, and some Adams APC. Rinsed thoroughly. Clayed the entire car, then washed again with just Car Shampoo. Dried with Adams Detail Spray and my waffle weave towel. I pulled out my Sealant applicator (marked with "S" so it only sees Sealant ever, and cleaned/dried thoroughly before using) and shook it well, then sprayed on the applicator and started with a 2x2 section on the hood. Let it haze a bit and wiped off with a clean Adams single soft. This is where the problem occurred-It seemed like the sealant wouldn't wipe off clean and left behind some of the actual fibers of the towel on the hood where the sealant was applied with the applicator. Tried to wipe clean and it seemed to spread the fibers of the towel even worse. It was very frustrating and I actually switched a different brand sealant to finish that coat/car. The issue didn't happen with the other guys sealant when I went to "plan B". No pics as I was trying to be efficient and didn't have time to stop and photograph said problem.
Anything you can think of that I'm doing wrong? I've used the Adam Quick sealant prior with no issue but I have about 3 cans of it that I'm not wanting to reach for now. Any input? I appreciate you feedback.
Purple87SS
14 answers to this question
