Kickerz71 Posted June 1, 2015 Share Posted June 1, 2015 Guys I purchased quick sealant and of course didn't read the instructions I just sprayed the rim and let it dry, issue is once dried I see run marks. Looks like watermarks/spotting. What can clean this off? I tried the wheel cleaner and clay bar but not really working out Any suggestions? Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 2, 2015 Share Posted June 2, 2015 There are tons of videos. Are you polishing to remove defects? Perhaps a pic of them would help with a plan of attack. If they are clearcoated you will polish/correct and protect with sealant just like paint. I recommend a thorough cleaning with plenty of brushes and Adams Deep Wheel Cleaner first off. Link to comment Share on other sites More sharing options...
0 mc2hill Posted June 1, 2015 Share Posted June 1, 2015 It will probably take some polish to remove the dried QS, Try Revive or PFP by hand. Link to comment Share on other sites More sharing options...
0 Gen9Rolla Posted June 1, 2015 Share Posted June 1, 2015 It will probably take some polish to remove the dried QS, Try Revive or PFP by hand. This. Quick Sealant can be pretty hard to get off Kickerz71 1 Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 1, 2015 Share Posted June 1, 2015 ^^^ correct. Before polishing you can also try simply reactivating the product. Spray some more QS onto an app and spread over the problem area. Immediately wipe off. If that doesn't work just polish and it should come off for you. Kickerz71 and THE Mook 2 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 1, 2015 Share Posted June 1, 2015 Guys I purchased quick sealant and of course didn't read the instructions PT3, AvsBest and Kickerz71 3 Link to comment Share on other sites More sharing options...
0 Kickerz71 Posted June 2, 2015 Author Share Posted June 2, 2015 ^^^ correct. Before polishing you can also try simply reactivating the product. Spray some more QS onto an app and spread over the problem area. Immediately wipe off. If that doesn't work just polish and it should come off for you. I tried to add another coat of sealant however it didn't help. Can you guide me on polishing the rims? They are on a camaro factory wheels and are finished with clear coat. Thanks Link to comment Share on other sites More sharing options...
0 Kickerz71 Posted June 3, 2015 Author Share Posted June 3, 2015 Well I was able to polish out the sealant Now I'll make sure to read the instructions next time.... Link to comment Share on other sites More sharing options...
0 PT3 Posted June 3, 2015 Share Posted June 3, 2015 Well I was able to polish out the sealant Now I'll make sure to read the instructions next time.... That's a novel idea. ; ) Glad it worked out for you. Link to comment Share on other sites More sharing options...
0 BitterGreg Posted June 4, 2015 Share Posted June 4, 2015 (edited) Well I was able to polish out the sealant Now I'll make sure to read the instructions next time.... typical man. Edited June 4, 2015 by BitterGreg Link to comment Share on other sites More sharing options...
Kickerz71
Any suggestions?
9 answers to this question
