Kickerz71 Posted July 5, 2015 Share Posted July 5, 2015 Love the product however when I spray it on my BF All terrains I find the dye from the spray will make the white letters turn yellowish. I usually will spray, let set then wipe off the excess. Link to comment Share on other sites More sharing options...
Chris@Adams Posted July 5, 2015 Share Posted July 5, 2015 I too have white lettering on my truck tires, I spray on the foam block then wipe on the tires. When done I take the clean edge of the foam and wipe the white letters off. Link to comment Share on other sites More sharing options...
Bill T. Posted July 13, 2015 Share Posted July 13, 2015 I recently picked up a bottle of tire shine at Summit..its been a LONG time since i have been that impressed with a car product. BRAVO Link to comment Share on other sites More sharing options...
TheBurninator Posted July 13, 2015 Share Posted July 13, 2015 You can always follow up with using a MF utility towel to wipe off from the lettering. Avoiding the lettering the best you can will probably help as well Link to comment Share on other sites More sharing options...
Team Adam's Posted July 13, 2015 Share Posted July 13, 2015 Something to keep in mind - often time discoloration on white lettering isn't the product, its transfer from the vulcanized (black) rubber and the antiozonant as you wipe the product over the surface. White lettering should always be avoided when applying a dressing. Spray onto the applicator and spread without crossing the whites as much as possible. Link to comment Share on other sites More sharing options...
Kickerz71 Posted July 14, 2015 Author Share Posted July 14, 2015 I will always clean the tire and scrub the letter using a brush. I usually spray the tire shine, allow to dry a little then wipe off excess. I'll try to spray the sponge first and avoid the white lettering. Link to comment Share on other sites More sharing options...
07stanggt Posted July 15, 2015 Share Posted July 15, 2015 Something to keep in mind - often time discoloration on white lettering isn't the product, its transfer from the vulcanized (black) rubber and the antiozonant as you wipe the product over the surface. White lettering should always be avoided when applying a dressing. Spray onto the applicator and spread without crossing the whites as much as possible. Agreed, but I do not have any issue using SVRT on my white letter tires, maybe because of the white pigment in the SVRT. I will have to agree with Kickerz71, using Tireshine does discolor the white lettering if not wiped off. I have now switched to SVRT on my truck and all oter vehicles get Tireshine. Both great products !! ledger64 1 Link to comment Share on other sites More sharing options...
ledger64 Posted July 15, 2015 Share Posted July 15, 2015 good info. another reason why I will stick with svrt Link to comment Share on other sites More sharing options...
BluePoncho Posted July 18, 2015 Share Posted July 18, 2015 I must be missing something. If I had to rank my least favorite products it would be a tie between tire shine and old glass cleaner for the simple fact that at the price point there seem to be better options that last longer at the big box stores Link to comment Share on other sites More sharing options...
goheels Posted July 18, 2015 Share Posted July 18, 2015 I must be missing something. If I had to rank my least favorite products it would be a tie between tire shine and old glass cleaner for the simple fact that at the price point there seem to be better options that last longer at the big box stores I would add the undercarriage spray to the list. The staining that results from that product keep me from ever reusing it. While I know there are a number of steps that need to be done in precaution (paper towels on floor, using block sponges to get excess, ect.) it just isn't worth the risk on my brand new floors. The smell is the only pleasant thing about the product IMHO. Link to comment Share on other sites More sharing options...
