Did I get borked foam gun sprayer?
I ordered the foam gun set right when announced so pretty sure I got one of the first shipments. Wondering if anyone else has issues with the spray gun being inconsistent or if just me? I noticed in several videos how smooth it is from spray to stream when handle pressure adjusted..whereas mine if not pressed all the way to stream it catches in a 'side-stream' like shooting out at an angle, really annoying. Hard to get a spray even.
Just me.. ? :/
Agreed with all above.
Check for a clog first, make sure the trigger assembly isn't bent and is moving freely, also make sure the female fitting on the end of the trigger isn't overly tight. It needs to be threaded on just enough to make full contact with the washer, over torquing it causes the washer to squeeze out and if it does could be in the path of the water, causing an unusual or mis-directed spray pattern.
If all else fails, give us a call at 866-965-0400 and we'll certainly take care of you.
