Kickerz71 Posted January 11, 2016 Share Posted January 11, 2016 Hi everyone, Newby question here, I just got my first polisher, so I went with the PC. I need pads for it now but what's the difference between CSS or flat pads? What one do you recommend? Thanks in advance Skeebo 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted January 11, 2016 Share Posted January 11, 2016 These Gen 5 pads will do you a great job! Adam's 6" Gen5 Pad Bundle Our latest generation polishing pad system, designed to work with the Rupes 15mm Bigfoot or Porter Cable 7424 equipped with a 5" backing plate. http://adamspolishes.com/shop/exterior/adam-s-gen5-6-pad-bundle.html Link to comment Share on other sites More sharing options...
0 Kingsford Posted January 11, 2016 Share Posted January 11, 2016 (edited) I really like CCS Pads for the PC and Flex. The thought behind the shape of the CCS pads is that the texture of the design distributes polish more evenly on a surface while absorbing less polish into the pad itself... It also helps prevent the pad from jumping or skipping around. Edited January 11, 2016 by Kingsford Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted January 11, 2016 Share Posted January 11, 2016 I get great results with our older Gen4 and our newer Gen5 pads, and I have used CCS-style pads in the past with no major complaints. It is important to note though that those pads are not color coordinated to our polishes, so if you go that route, make sure you buy the correct pads for the polishes you are using. I like the flat design of our Gen5 pads as they seem to correct a little faster for me, and the foam seems to be more forgiving and doesn't tear up as easily as our older wave-style pads if you don't have perfect technique with the machine, i.e. putting too much weight on one side of a pad vs. keeping the pad face flat against the surface area. The center cooling hole also allows for the pads to generate less heat. My winning combo on most of the hammered vehicles I've worked on lately has been the orange microfiber pad with Paint Correcting Polish followed up by the white foam pad with Paint Finishing Polish. Link to comment Share on other sites More sharing options...
0 JD_Alaska Posted February 4, 2016 Share Posted February 4, 2016 I 2nd Dans comments on the micro fiber pads. I've had great results using them and much faster than foam pads IMO. Link to comment Share on other sites More sharing options...
Kickerz71
Hi everyone,
Thanks in advance
4 answers to this question
