GXPaycheck Posted October 26, 2016 Share Posted October 26, 2016 So, is this for hard plastic trim or can it be used on rubber weatherstripping as well? Link to comment Share on other sites More sharing options...
0 gabhart Posted October 26, 2016 Share Posted October 26, 2016 I'm thinking it will not work well with rubber that flexes a lot. Sounds like when it cures it will be somewhat hard (ceramic) and may crack if flexed too much? Link to comment Share on other sites More sharing options...
0 Rich Posted October 27, 2016 Share Posted October 27, 2016 Hard plastic. Adam mentions it is like a ceramic coating. I've never known those to be good for porous things like weatherstripping. Link to comment Share on other sites More sharing options...
0 TheWolf Posted October 27, 2016 Share Posted October 27, 2016 So, is this for hard plastic trim or can it be used on rubber weatherstripping as well? Are you referring to exterior rubber trim, or the weather-stripping inside the door jamb? Yes, it can be used on exterior rubber trim. No, it is not for weather-stripping like the kind in door jambs. Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted October 28, 2016 Author Share Posted October 28, 2016 Another one, if you do get water spotting from moisture during the curing period, how do you correct it? Link to comment Share on other sites More sharing options...
0 gabhart Posted October 28, 2016 Share Posted October 28, 2016 Brian, if you are asking questions because you are considering trying this out please let me know. I would like to see the results if you pull the trigger! Link to comment Share on other sites More sharing options...
0 Wolfeman Posted October 28, 2016 Share Posted October 28, 2016 Is this only for faded plastic or is it meant to protect new plastic as well? Link to comment Share on other sites More sharing options...
0 Wild2003ss Posted October 29, 2016 Share Posted October 29, 2016 Is this only for faded plastic or is it meant to protect new plastic as well? It can be used on new trim as well. It will keep it new longer Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted October 30, 2016 Author Share Posted October 30, 2016 Mods, how about adding these to the FAQ thread and deleting this one. Thanx! TheWolf 1 Link to comment Share on other sites More sharing options...
0 hemi1300 Posted October 30, 2016 Share Posted October 30, 2016 What if u mess up the application and need to remove the coating, is this possible? Link to comment Share on other sites More sharing options...
0 TheWolf Posted October 30, 2016 Share Posted October 30, 2016 Mods, how about adding these to the FAQ thread and deleting this one. Thanx! Thanks Brian, I knew there was a thread that I missed posting the link to the new FAQ thread. We will work get these answers included in this thread: Tim Coating | FAQ's | Discussion (I am also going to lock this thread to direct people to post their questions in the above thread, so all the info is in one place) Link to comment Share on other sites More sharing options...
GXPaycheck
10 answers to this question
