Jrosacker Posted December 21, 2016 Share Posted December 21, 2016 I am out of wheel cleaner so I was wondering if I could use APC for now? Thanks in advance. Link to comment Share on other sites More sharing options...
0 shane@detailedreflections Posted December 21, 2016 Share Posted December 21, 2016 APC will clean a rim. It will not dissolve the brake dust and iron in them though as wheel cleaner does. So the answer to your question is...is depends on your goal. Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted December 21, 2016 Share Posted December 21, 2016 The quick answer is yes, you can use APC to clean most wheel finishes, but it will not be as effective as Wheel Cleaner, as Shane mentions above. All of the same precautions apply as if you were using Wheel Cleaner: Only spray APC on wheels that are cool to the touch Clean one wheel at a time. Do not let APC dry onto the wheels Do not use APC on bare polished aluminum wheels Adam demonstrates wheel cleaning with APC in the Daily Driver video falcaineer 1 Link to comment Share on other sites More sharing options...
0 Jrosacker Posted December 21, 2016 Author Share Posted December 21, 2016 The quick answer is yes, you can use APC to clean most wheel finishes, but it will not be as effective as Wheel Cleaner, as Shane mentions above. All of the same precautions apply as if you were using Wheel Cleaner: Only spray APC on wheels that are cool to the touch Clean one wheel at a time. Do not let APC dry onto the wheels Do not use APC on bare polished aluminum wheels Adam demonstrates wheel cleaning with APC in the Daily Driver video is he using it full strength?? Link to comment Share on other sites More sharing options...
0 blcksilv08 Posted December 22, 2016 Share Posted December 22, 2016 is he using it full strength?? Yes, that is full strength. If you follow the tips Dan posted you won't have any issues. Link to comment Share on other sites More sharing options...
Jrosacker
4 answers to this question
