EPHIOS Posted August 17, 2020 Share Posted August 17, 2020 Got an amazing results after the application of Graphene Spray Coating. What are the shelf life of an unopened bottle and opened (with original cap on)? Thank you. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 17, 2020 Share Posted August 17, 2020 It should last a few years, the main thing is keep it stored in climate controlled location. All of your products as far as that goes should be stored not below 45* and not above 85*. Link to comment Share on other sites More sharing options...
0 EPHIOS Posted August 17, 2020 Author Share Posted August 17, 2020 49 minutes ago, Chris@Adams said: It should last a few years, the main thing is keep it stored in climate controlled location. All of your products as far as that goes should be stored not below 45* and not above 85*. Is that both opened and unopened? Also, is there a reason why it came with two sprayer? Maybe it can clog-up overtime? Thanks. Link to comment Share on other sites More sharing options...
0 galaxy Posted August 17, 2020 Share Posted August 17, 2020 Not may, will. After using any coating, remove the sprayer and trash it, and store it with the original cap. Link to comment Share on other sites More sharing options...
0 EPHIOS Posted August 17, 2020 Author Share Posted August 17, 2020 3 hours ago, galaxy said: Not may, will. After using any coating, remove the sprayer and trash it, and store it with the original cap. I have already used the spray coating in three different occassions, and I been rinsing it after each use. Its been working fine. Kickerz71 and kaj41354 2 Link to comment Share on other sites More sharing options...
0 falcaineer Posted August 17, 2020 Share Posted August 17, 2020 49 minutes ago, EPHIOS said: I have already used the spray coating in three different occassions, and I been rinsing it after each use. Its been working fine. +1. I've found if you remove the sprayer and spray till it's empty and wipe the nozzle, you can reuse it. I do usually store mine with the cap, though. kaj41354 1 Link to comment Share on other sites More sharing options...
0 galaxy Posted August 18, 2020 Share Posted August 18, 2020 1 hour ago, falcaineer said: +1. I've found if you remove the sprayer and spray till it's empty and wipe the nozzle, you can reuse it. I do usually store mine with the cap, though. Yup...that works too. I've done that a few times. Main point being, store with the original cap. I've got sooooo many sprayer nozzles from Adam's built up from shipments over the years that it's literally not worth my time to clean one, LOL! falcaineer 1 Link to comment Share on other sites More sharing options...
EPHIOS
Thank you.
6 answers to this question
