Meathead Posted August 24, 2021 Share Posted August 24, 2021 Can I put this over an excellent coat of F11 ceramic or do I have to strip the F11? Link to comment Share on other sites More sharing options...
The Guz Posted August 24, 2021 Share Posted August 24, 2021 Shouldn't take much to remove F11. If you want the max performance of the coating then prep and have the coating bond to the painted surface. Link to comment Share on other sites More sharing options...
Rich Posted August 24, 2021 Share Posted August 24, 2021 Exactly right Guz. You want the ceramic coat to bond with the paint. If you need a boost to the shine, use the CS3, the Graphene CS3 or Graphene Detail Spray. Link to comment Share on other sites More sharing options...
WhiteShadow89 Posted September 28, 2021 Share Posted September 28, 2021 (edited) I agree with Guz. Get rid of F11 so the ceramic can bond to the paint. I can't stress enough how important the prep work prior to applying a true ceramic coating is. I wanted to mention this, but to do a ceramic proper imo (like Adam's graphene ceramic 10h) you should do the following below: -Full decontamination: Adam's strip wash, fall out/Iron spray and clay. -Paint correct: Correct the defects in your paint via buffing. -Surface Prep: Use this product to remove an polishes and etc to ensure the body work is clean and the ceramic bonds 100% From here you can install a ceramic. Edited September 29, 2021 by WhiteShadow89 Link to comment Share on other sites More sharing options...
