GXPaycheck Posted May 9, 2022 Share Posted May 9, 2022 Is there a way to test towels before use to determine whether or not they are saturated with whatever ceramic product you are using? Link to comment Share on other sites More sharing options...
0 The Guz Posted May 9, 2022 Share Posted May 9, 2022 What ceramic products are be referred to? Sprays? Coatings? Spray Coatings? Link to comment Share on other sites More sharing options...
0 Rich Posted May 10, 2022 Share Posted May 10, 2022 If you want to be sure, just clean them. Soak them for a while or even over night in a bucket with Dawn (that's what I use). And then wash them with Micro Revitalizer and hot water (I know....use warm or cold cause it's better for the fabric). I like the results I get with hot water. And line dry them or air dry them in the dryer. Or just use new towels. Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted May 12, 2022 Author Share Posted May 12, 2022 On 5/9/2022 at 12:56 PM, The Guz said: What ceramic products are be referred to? Sprays? Coatings? Spray Coatings? Any of the above. That being said, currently I’m only using spray products like G&G and CS3. Link to comment Share on other sites More sharing options...
0 Rich Posted May 12, 2022 Share Posted May 12, 2022 9 hours ago, GXPaycheck said: Any of the above. That being said, currently I’m only using spray products like G&G and CS3. That's all i use is the spray ceramics. Link to comment Share on other sites More sharing options...
0 The Guz Posted May 13, 2022 Share Posted May 13, 2022 16 hours ago, GXPaycheck said: Any of the above. That being said, currently I’m only using spray products like G&G and CS3. You will know when they no longer absorb water and just push the water around. Either wash your towels right away or soak them in some microfiber detergent if you will not wash them the same day. Link to comment Share on other sites More sharing options...
0 GXPaycheck Posted May 13, 2022 Author Share Posted May 13, 2022 6 hours ago, The Guz said: You will know when they no longer absorb water and just push the water around. Either wash your towels right away or soak them in some microfiber detergent if you will not wash them the same day. That’s what I usually do. Link to comment Share on other sites More sharing options...
GXPaycheck
6 answers to this question
