So I have a Rupes LHR Mark II. Last weekend I did a full paint correction using some new Rupes microfiber pads. I think this is the 4th vehicle I have buffed with the exception of some spot work with bird etchings.
About 1/2 way through the pads were starting to slip off center and would not hold. I could see some smearing on the velcro print on the back of the pad and they were warm.
At times I had the speed up to 4 and 5. I really did not make long runs with about 90 seconds being the longest pass I would guess.
I am thinking I overheated the pads and toasted the backing plate. I have a new backing plate on order and will see how that goes. I have tried to research the subject and only thing I found was Dylan talking about the Mark II having more power than the first generation and to slow things down.
So it appears to me, with microfiber pads I need to keep the speed to 3 or less and clean with air to cool between passes.
Anyone with similar experiences? A backing plate is almost $50 with shipping so I cant afford to be replacing backing plates.
rrmccabe
Thoughts?
6 answers to this question
