Kingsford Posted May 30, 2010 Share Posted May 30, 2010 Hey guys, when ever I use my Hex Grips or Flip Pad I was them by hand but they never fully dry for a few days of cooking in the sun. Would it be safe to put them in the dryer on Regular and let the heat dry them? Link to comment Share on other sites More sharing options...
ExpressThis13 Posted May 30, 2010 Share Posted May 30, 2010 I would say not. I use some APC and rinse em out with water and they come clean and ring them out really good and they should dry farily quickly. Link to comment Share on other sites More sharing options...
Nordgrey Posted May 30, 2010 Share Posted May 30, 2010 That's what I do. Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 30, 2010 Share Posted May 30, 2010 x2 Link to comment Share on other sites More sharing options...
11chevz71 Posted May 30, 2010 Share Posted May 30, 2010 :iagree:X3 I had to do it Link to comment Share on other sites More sharing options...
Laguna Posted May 31, 2010 Share Posted May 31, 2010 If you put them in the dryer, you can, but it needs to be air spin, where all it does is simply spin it and push air into it. Make sure that it doesn't heat up at all. The best thing to do is put a white shirt into the dryer on "air" for 5 minutes, stop and touch it right away and see if it's hot at all. If not, feel free to spin them for awhile. If it is, ring them out and let them air dry by sitting there. Link to comment Share on other sites More sharing options...
Kingsford Posted May 31, 2010 Author Share Posted May 31, 2010 I would say not. I use some APC and rinse em out with water and they come clean and ring them out really good and they should dry farily quickly. Thats what I've been doing and they seem to never dry out. I've set them out in the sun 3 days in a row now and they are still wet. Its like 90 Degrees out too. Link to comment Share on other sites More sharing options...
DeadGreg Posted May 31, 2010 Share Posted May 31, 2010 Thats what I've been doing and they seem to never dry out. I've set them out in the sun 3 days in a row now and they are still wet. Its like 90 Degrees out too. As other's have said, ring them out as best as possible. Then what I do is fling the water out, kinda like using the PC to dry out a wet pad by rotational force, but by hand. I hold the pad over my head then swing my arm down towards the ground to force more water out. After that, I'll leave the pad to dry on a wire rack next to the dehumidifier. The dehumidifier is key here because it'll remove the water in the air. Link to comment Share on other sites More sharing options...
hawgfan Posted May 31, 2010 Share Posted May 31, 2010 I put mine in the dryer on extra low heat or air dry, it seems to be working. What could be the draw backs from doing this, is my question???? Link to comment Share on other sites More sharing options...
BRZN Posted May 31, 2010 Share Posted May 31, 2010 After washing them out, I leave all my pads and applicators sit in a dish strainer out in the garage by the "shop" sink, this allows air to circulate all around them. The denser the foam the longer it takes to some to dry, and it all depends on the humidity. 90 degrees doesn't mean anything if the humidity is high too. Link to comment Share on other sites More sharing options...
gymrat7953 Posted May 31, 2010 Share Posted May 31, 2010 mine sit on the grit guard on top of the tool box until dry Link to comment Share on other sites More sharing options...
ExpressThis13 Posted May 31, 2010 Share Posted May 31, 2010 Well I store all my stuff inside so when I do mine they are sitting in my basement on a table until dry which doesnt seem to take long or maybe I just have prime conditions for it. Link to comment Share on other sites More sharing options...
Oupavoc Posted May 31, 2010 Share Posted May 31, 2010 well i clean them with a few sprays of apc and work it in and then wash them out good and then ring them out as most as possible then lay them against the grit guard in the bucket Link to comment Share on other sites More sharing options...
Kingsford
12 answers to this question
