FAQ - "Whats the best wax for black paint?"
  • Please log in to reply
55 replies to this topic
#1 Team Adam's
Team Adam's
    Here to Help!
  • Team Member
  • 20,309 posts
Posted 01 September 2011 - 05:42 PM
"I have a black car and I want it to look its best. What wax is the best for black cars?"
Its a common question we see, and probably one you see posted on a variety of forums. I'm here to dispel any myths, misconceptions, or rhetoric about color specific waxes.
The very first thing to understand is that your choice of wax really has very little to do with the color of your vehicle. Wax doesn't know what color paint paint its being applied to, nor will it change characteristics based on what color paint is under it. Your choices of wax need to be predicated more on your desired effect: Durability // Aesthetics // Ease of Use // Price
Yes, there are waxes out there marketed as to only be used on a specific color. I'm here to tell you they're more snake oil than hard facts. Some contain oily tinted fillers that will give you a short lived 'masking' effect to help hide imperfections, but this has more to do with the filling ability of the product than it does with the fact that its dyed black. The same effect can be had using a NON-tinted glaze, like Adam's Brilliant Glaze, so the addition of color specific dyes is moot.
Waxes DO NOT remove swirl marks or correct paint issues! This is a common misconception among many newcomers to detailing. Wax is a coating, nothing more. In order to remove imperfections like swirl marks, spider webbing, scratches, etc. a car will need to be polished (most likely by machine) Once the paint is perfected the wax can provide the most possible enhancement. Applying the very best wax to poorly prepped paint will only result in disappointment.
That being said certain colors do display a wider range of characteristics that can be ENHANCED by your wax choice. For example black is a color that, when cleaned and corrected, will display great depth and a 'wet look' as opposed to colors like silver or white. Using a carnauba wax on black will generally produce a deeper/wetter look, assuming the paint has been properly corrected and prepped. That same wax applied to silver or white won't have the same effect, thats not to say there isn't an enhancement, but its less noticeable as white/silver aren't colors that display depth to begin with.
SO HOW DO I CHOOSE THE RIGHT WAX FOR MY BLACK CAR?
Your Last Step Product (LSP) should be chosen based on your criteria for what you're trying to achieve. Below are some outlined characteristics to help you understand what each products strengths are.
  • SEALANTS - Products like Adam's MSS or the soon to be introduced Spray Sealant are synthetic. They contain no naturally occurring 'wax' but many people will still refer to them as a wax. Sealants are typically more durable than a naturally occurring wax due to their overall higher melting point and detergent resistance. Products like these are typically the best choice for someone seeking the longest lasting protection for their paint. Sealants are also typically known for very bright, reflective, mirror like, shines. They tend to lack the depth/wetness of a natural wax but still give very intensely reflective shine.
  • GLAZES - Products like Adam's Brilliant Glaze are excellent for enhancing gloss on a finish and are actually made using some carnauba wax. The drawback is that due to their composition glazes are not intended to provide protection. They are highly susceptible to heat and detergents, meaning that glazes alone, though good for paint enhancement in a hurry, are not long term solutions for protection. Use glazes in conjunction with sealants or waxes for better results and protection.
  • BASIC CARNAUBA - This is a term that is very familiar to most detailing enthusiasts and car nuts in general, but its also widely misunderstood. Carnauba is a naturally occurring wax harvested from a variety of different palms and can come in varying grades. Typically the quality/grade of the wax dictates the durability, ease of application, and how it will enhance a cars finish. Liquid waxes on average utilize a lower grade yellow carnauba, which is relatively inexpensive and generally easy to apply. Adam's Buttery Wax for example utilizes these types of waxes, blended with other ingredients resulting in an easy to apply, easy to remove, 'quick' liquid wax. The trade off for these characteristics are lowered heat/detergent resistance and slightly less enhancement to the paint as compared to waxes made with higher grade carnauba.
  • PREMIUM CARNAUBA - On the other hand Adam's Americana Paste Wax is comprised of the highest grade of carnauba available. This specific type of carnauba is chosen for its higher heat and detergent resistance. In addition with the physical particles of wax being substantially larger than its lower grade cousins this wax will provide more enhancement of depth and gloss on dark paint. These characteristics are more exaggerated on black and dark colors, but are present on any color the wax is applied to.
In the end, what I hope you take away from this thread, is that the choice of 'wax' has very little to do with the color of the vehicle and more about what you're trying to achieve. Waxes can only do so much to enhance whats there, proper paint correction and prep do more for black than wax can. A wax is meant first to serve as a layer of protection and secondly a way to enhance the characteristics of the color a small amount. So choose your last step product (sealant, glaze, wax, or a combination) based on what your primary goal is - If you're all about protection go with the sealant. If kicking that gloss up just a little is your goal, then carnauba is the way to go! Also don't be afraid to experiment to find your shine.... as much as detailing is a process, its very much an art, and like art very much subjective. Find the product(s) you think make your car look best and enjoy!
Hope you find this helpful and happy detailing! :pc:
Edited by Dylan@Adams, 09 May 2012 - 04:39 PM.
  • 2012stang5.0, Sean Ryan and Geebee like this
#2 ChargerMatt
ChargerMatt
    Master AF Detailer
  • Members
  • 1,833 posts
  • Real Name: Matt
Posted 01 September 2011 - 06:02 PM
Excellent post Dylan, it is sure to clarify some things up
Posted Image
#3 XQIZT
XQIZT
    Authorized Dealer
  • Authorized Dealer
  • 1,377 posts
  • Real Name: Mike
Posted 01 September 2011 - 06:07 PM
:2thumbs: EXCELLENT explanation in plain English.
Factory-Trained and Authorized Adam's Distributor
Orlando, FL
Mike Augello
407-257-9604
mike@xqizt-automotive.com
"Like" us on Facebook: www.facebook.com/XQIZTauto
Posted Image
#4 Team Adam's
Team Adam's
    Here to Help!
  • Team Member
  • 20,309 posts
Posted 01 September 2011 - 06:08 PM
Thanks. I know most of our 'seasoned veterans' around here already know this stuff, but for newcomers or someone just casually stumbling into the forums will surely have this question. I think I answer it a half dozen times a week.
#5 FP
FP
    FP's Rides
  • Members
  • 105 posts
  • Real Name: FP
Posted 01 September 2011 - 06:19 PM
Excellent Dylan. I'd love to see this over at CICCI. Can I pst this there, or please post it when you get a chance.
Finishing Polish
sig2
#6 Chewy
Chewy
    Surgical Sith
  • Members
  • 10,256 posts
  • Real Name: Christopher
Posted 01 September 2011 - 07:40 PM
My wet paint came from hours of PC and Flex usage. Nothing more, nothing less... MSS just adds pop.
Sent from my iPhone4 using special algorithms and data nodes!
#7 XQIZT
XQIZT
    Authorized Dealer
  • Authorized Dealer
  • 1,377 posts
  • Real Name: Mike
Posted 01 September 2011 - 07:55 PM
"...................or the soon to be introduced Spray Sealant are synthetic..........."
Way to just casually slip that in there!
Orlando, FL
Mike Augello
407-257-9604
Posted Image
#8 Team Adam's
Team Adam's
    Here to Help!
  • Team Member
  • 20,309 posts
Posted 01 September 2011 - 07:56 PM
LOL... so you caught that did ya?
#9 Team Adam's
Team Adam's
    Here to Help!
  • Team Member
  • 20,309 posts
Posted 01 September 2011 - 08:01 PM
Nice work Dylan, this will definitely help people out.
BTW, what's up with the new Spray Sealant???
#10 Chewy
Chewy
    Surgical Sith
  • Members
  • 10,256 posts
Posted 01 September 2011 - 08:19 PM
It's sealant and you spray it... :jester:
#11 FP
FP
    FP's Rides
  • Members
  • 105 posts
  • Real Name: FP
Posted 01 September 2011 - 08:25 PM
Wasn't the original Glaze in a spray bottle?
sig2
#12 ktn65
ktn65
    Learning Detailer
  • Members
  • 99 posts
  • Real Name: Keith
Posted 01 September 2011 - 08:44 PM
:jester: So they thinned down MSS and put a pump on it??? :jester:
:lolsmack:
#13 Chewy
Chewy
    Surgical Sith
  • Members
  • 10,256 posts
Posted 01 September 2011 - 08:47 PM
Yes, but these are two TOTALLY different products. Don't mistake a glaze with a sealant.
Sealants add protection, whereas glazes add depth and smooth out imperfections.
Oh, and NO pump here folks... This is something TOTALLY new and amazing! :thumbsup:
Chris
#14 bjoeaull
bjoeaull
    Master AF Detailer
  • Members
  • 743 posts
  • Real Name: BJoe Aull
Posted 01 September 2011 - 09:29 PM
So would it be a spray on and wipe off, or spray on and leave it?
1969 Firebird white (toy)
2016 Silverado Crew HD High Country Black (DD)
2016 Denali XL Black (family)
#15 Chris@Adams
Chris@Adams
    God, Family, Cars In That Order.......
  • Administrators
  • 22,006 posts
  • Real Name: Chris Toth
Posted 01 September 2011 - 10:13 PM
Nice job Dylan!:cheers:
Pontiac, Gone But Not Forgotten! GTO 1 OF 136
Adam's Polishes is the Officially Licensed Car Care Product of Corvette & Camaro.
use the code SHINEON for 10% off your next order
youtube.com/adamspolishes | instagram.com/adamspolishes
#16 mc2hill
mc2hill
    Master AF Detailer
  • Official Product Tester
  • 7,614 posts
  • Real Name: Michael
Posted 02 September 2011 - 01:38 AM
Great explanation Dylan! :2thumbs:
Paying for my sins of nutrition at the steps of Lanny Potts
#17 J Tegeler
J Tegeler
    black mirrors
  • Members
  • 1,578 posts
  • Real Name: Jonathan
Posted 02 September 2011 - 02:04 AM
nice post up Dylan
#18 ktn65
ktn65
    Learning Detailer
  • Members
  • 99 posts
  • Real Name: Keith
Posted 07 September 2011 - 10:12 PM
Chris
Soooo, it's any more info on this TOTALLY new and amazing Spray Sealant???? :drool:
#19 The Ryan
The Ryan
    Squirrel!
  • 2,828 posts
  • Real Name: Ryan
Posted 07 September 2011 - 10:19 PM
My lips are sealed :lolsmack:
2015 TorRed Charger R/T Premium
#20 Team Adam's
Team Adam's
    Here to Help!
  • Team Member
  • 20,309 posts
Posted 07 September 2011 - 10:54 PM
I thought they looked shinier than usual :jester:
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
