So I've got a five gallon detailing spray jug that I cracked open (literally, had to pop holes in it with a screw driver for breathing and to knock out the nozzle fitting) for the first time today. I'm finding the nozzle nearly useless for refilling the spray bottles. If you open it a little bit, you get a drizzle, if you open it enough so that it doesn't take ten minutes to fill the bottle, the liquid seems to come spray out from the edges of the nozzle, which happens to be the same diameter as the spray bottle neck, so you end up with detail spray everywhere. Short of a funnel, which I plan to go buy tomorrow, is there a trick to easily dispense from the five gallon to the spray bottles?
pdisme
15 answers to this question
