Gambrinus Posted September 23, 2014 Share Posted September 23, 2014 I dropped my Americana and it broke into a lot of pieces.. Can I microwave it to get it back to one piece ? Thanks in advance Link to comment Share on other sites More sharing options...
0 egott_91 Posted September 23, 2014 Share Posted September 23, 2014 There have been many posts on here about putting it in boiling water to help melt it. I think a microwave might be too harsh. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted September 23, 2014 Share Posted September 23, 2014 DO NOT microwave it! That generates too much heat, too quickly and will "burn" the wax. Here's the best way to do it: Prepare a shallow baking dish with about an inch of water in it, or enough to go about halfway up the side of the wax pot. Heat it up on the stove, and place the wax pot itself in the hot water. As the pot warms, it will slowly melt the wax pieces in it to a liquid state. Once everything is melted, remove the pot from the water and allow it to cool on the coutner. Do not refrigerate to accellerate the cooling, let it happen at room temperature. Chris@Adams 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted September 23, 2014 Share Posted September 23, 2014 Or you can just use it like it is.......as long as you can get it on your applicator that's all that matters. Beemer and GerryC 2 Link to comment Share on other sites More sharing options...
0 LFairbanks Posted September 23, 2014 Share Posted September 23, 2014 (edited) Read this thread. http://www.adamsforums.com/topic/16962-is-my-americana-pretty-much-ruined-pic-inside/?hl=%2Bamericana+%2Bruined Looks like the pictures that were posted were deleted by the poster who originally tried it. It did work well. Looked brand new. Biggest trick is to only melt what is necessary and melt it slow. It won't take much heat. The slower the better. Edited September 24, 2014 by LFairbanks Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted September 23, 2014 Share Posted September 23, 2014 You can always dump all of it out of the container into a stainless steel pot, heat it on low to melt it to complete liquid, and re-pour it into the Americana container and let it set up nice and firm again in the container. (stir it up prior to pouring) Should be good as new. Link to comment Share on other sites More sharing options...
0 LFairbanks Posted September 23, 2014 Share Posted September 23, 2014 You can always dump all of it out of the container into a stainless steel pot, heat it on low to melt it to complete liquid, and re-pour it into the Americana container and let it set up nice and firm again in the container. (stir it up prior to pouring) Should be good as new. But then you have all that residue that gets left in the pot and not in your container. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted September 24, 2014 Share Posted September 24, 2014 But then you have all that residue that gets left in the pot and not in your container. If you heat it up all the way it literally should run out like water, not soup. Paste wax is mostly liquid solvent (45%) by composition anyway, the rest is a blend of waxes and an oil agent of some sort. You'll have barely a lick of residue on that pot and can rinse the rest down the drain when done with hot water with no ill effects. Link to comment Share on other sites More sharing options...
0 LFairbanks Posted September 24, 2014 Share Posted September 24, 2014 (edited) If you heat it up all the way it literally should run out like water, not soup. Paste wax is mostly liquid solvent (45%) by composition anyway, the rest is a blend of waxes and an oil agent of some sort. You'll have barely a lick of residue on that pot and can rinse the rest down the drain when done with hot water with no ill effects. Each to their own, I guess. I understand it pours out like a liquid, but not like water like your implying. It is cooling as your pouring it. And then to rinse the excess down your drain???? Who is to say that stuff isn't going to create some sort of magnet (for lack of a better word) to other household foods and what not that do get down the drain? Even without putting stuff that shouldn't be in your drain it still looks nasty and the walls of the pipes start collecting gunk. Especially on the horizontal runs. Edited September 24, 2014 by LFairbanks Link to comment Share on other sites More sharing options...
0 BitterGreg Posted September 24, 2014 Share Posted September 24, 2014 Not going to lie, the first time I read the thread title, I thought someone was detailing their bath tub. Team Adam's and Beemer 2 Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted September 24, 2014 Share Posted September 24, 2014 Each to their own, I guess. I understand it pours out like a liquid, but not like water like your implying. It is cooling as your pouring it. And then to rinse the excess down your drain???? Who is to say that stuff isn't going to create some sort of magnet (for lack of a better word) to other household foods and what not that do get down the drain? Even without putting stuff that shouldn't be in your drain it still looks nasty and the walls of the pipes start collecting gunk. Especially on the horizontal runs. If it really bothers you I'm sure a few spritzes of APC on your pan and a quick wipe after pouring into the tub should leave your pan ready for a normal wash with Dawn dish soap as normal. Didn't say I would pour it down the drain but you seem to be worried about it doing something to your pan. It's not candle wax here which will solidify in 3 seconds once spilled, melting a solvent based paste wax is much different. Link to comment Share on other sites More sharing options...
0 LFairbanks Posted September 25, 2014 Share Posted September 25, 2014 If you heat it up all the way it literally should run out like water, not soup. Paste wax is mostly liquid solvent (45%) by composition anyway, the rest is a blend of waxes and an oil agent of some sort. You'll have barely a lick of residue on that pot and can rinse the rest down the drain when done with hot water with no ill effects. If it really bothers you I'm sure a few spritzes of APC on your pan and a quick wipe after pouring into the tub should leave your pan ready for a normal wash with Dawn dish soap as normal. Didn't say I would pour it down the drain but you seem to be worried about it doing something to your pan. It's not candle wax here which will solidify in 3 seconds once spilled, melting a solvent based paste wax is much different. Not sure where I mentioned I was worried about a pan. Just making others aware of potential waste and hazards. Look at the picture and decide for yourself if that residue that is left is acceptable, and realize your only seeing the top of the jar. Not what is left in the bottom. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted September 25, 2014 Share Posted September 25, 2014 ...or you can just leave it in the pot it comes in, and skip the pouring step. LFairbanks and HydroBlueJK 2 Link to comment Share on other sites More sharing options...
Gambrinus
12 answers to this question
