buffalobob920 Posted June 3, 2016 Share Posted June 3, 2016 i have on my car called shotgun artillery fungus it comes from mulch and gets on the cars finish also you see it on house siding what is the safest way to remove from car finish Link to comment Share on other sites More sharing options...
0 chops1sc Posted June 3, 2016 Share Posted June 3, 2016 https://tennesseemobiledetailing.wordpress.com/2011/06/11/artillery-fungus/ Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted June 3, 2016 Author Share Posted June 3, 2016 Thanks for the info it's on my wife's car only in about ten spots on the hood of the car Link to comment Share on other sites More sharing options...
0 Odds and Ends Posted June 3, 2016 Share Posted June 3, 2016 Nice link! I learned about artillery fungus quite a few years ago and see it quite often. Author is correct that once you get the head off, the brown stain can be stubborn. Lots of patience is necessary, for sure. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted June 3, 2016 Author Share Posted June 3, 2016 Yes thanks what kind of abrasive polish do you recommend I know the article says use a clay bar after the plastic razor and then use a abrasive polish would Adams correction polish work or do I need something more abrasive Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted June 3, 2016 Share Posted June 3, 2016 (edited) Honestly try Wheel Cleaner as a fallout cleaner, let it dwell a few mins without drying, and use a gas pressure washer and keep it about 2 feet from the paint EDIT: I just read the article. Wow that stuff stinks - if you have plastic razor blades give it a whirl. Edited June 3, 2016 by Ricky Bobby Link to comment Share on other sites More sharing options...
0 Odds and Ends Posted June 3, 2016 Share Posted June 3, 2016 Last I checked, artillery fungus laughs at wheel cleaner! Xenit or Goo Gone (and other similar adhesive removers) will break down the sticky heads if they are fresh but the pesky brown dot remains. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted June 3, 2016 Author Share Posted June 3, 2016 Thanks for all of your suggestions I know it's a hard thing to remove but have to be careful of the finish Link to comment Share on other sites More sharing options...
0 Aussie Rowan Posted July 18, 2019 Share Posted July 18, 2019 My white car (medium sized SUV - Toyota Rav4) was progressively getting covered in black spots. I've read through lots of blogs and there doesn't seem to be a consensus. However, I decided to try the easiest... I used white vinegar and warm water with a ratio of approx. 1:10. It worked a treat. It took a good couple of hours to wipe down the whole car. I think I will need to go over it again, especially in the corners and joins, but it looks 100% better. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted July 23, 2019 Author Share Posted July 23, 2019 16 minutes ago, Salzburg said: wow, what? what's this discussion about? This is a old subject but arterial fungus comes from your mulch it’s a brown spot on your paint it kinda explodes and this microscopic brown spec goes into the air and goes on your house siding and if your car is close to the mulch on your flower bed it will land on your car go look it up google it left on the paint it is almost impossible to get it off without it etching the paint Link to comment Share on other sites More sharing options...
0 Sonny Posted October 22, 2021 Share Posted October 22, 2021 I used 'Tilex spray w/ bleach'. Sprayed it on then ran a non scratch kitchen 'Dobbie pad' over the dotted area and they came right off. EASY PEASY. Mine were on for 6 months. Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted October 22, 2021 Author Share Posted October 22, 2021 Did it leave a stain on the paint if it was white or a light color it may show on a dark color not so much Link to comment Share on other sites More sharing options...
0 Rich Posted October 23, 2021 Share Posted October 23, 2021 I wouldn't trust Tilex or any bleach product on paint. Same as I don't trust melamine sponges (Magic Erasers) on paint. buffalobob920 1 Link to comment Share on other sites More sharing options...
0 Peter Posted October 16, 2022 Share Posted October 16, 2022 (edited) They are all over my car !! How can get on the roof of a Highlander ? exploding spots from fungus! This is a first for me. I paid 100 $ to a car Detailer and the next day it was all over again …. So I moved the car to a different spot hoping ! My mulch is 2 years old … next to the driveway…. Help!!! there’s a fungus among us!! 🙃 Edited October 16, 2022 by Peter Spelling Link to comment Share on other sites More sharing options...
0 Peter Posted October 16, 2022 Share Posted October 16, 2022 Can I spray the mulch ? Link to comment Share on other sites More sharing options...
0 buffalobob920 Posted October 16, 2022 Author Share Posted October 16, 2022 2 hours ago, Peter said: Can I spray the mulch ? No I don’t believe it will work I removed mine completely and now used sweet pea mulch for a few years and no problem since it’s more expensive like everything else is right now Link to comment Share on other sites More sharing options...
buffalobob920
15 answers to this question
