Exterior detail.
Ls1transam
After almost being completely over Bronchitis. I got out this evening and washed, clayed and sealed my sisters car. This car needs polished bad. In the spring it will be polished and coated. This was just to get it through the winter. I first did a pre rinse to knock off all the non bonded dirt. Next I used Adam’s foam gun and foamed the car down to loosen the bonded contaminants. Rinsed again, and then did my 2 bucket wash. After washing, I rinsed the dirt and soap away. Foamed the car again to act as my clay lubricant and began claying the car. Dried with the old style Adam’s drying towel. Which basically just pushed the water around. I guess the temps made it more difficult with drying. Used my Rupes 15mm MKll and Adam’s grey foam pad to spread the non Adam’s sealant. Let it cure for 30 minutes and then wiped off with a single soft towel. Wheels were also sealed with a spray style sealant.
8 answers to this question
