I received my Adams Lug/Detail brush last week and I have used it quit a bit already. This is a tool that once you have one, you will use it A LOT! I had previously used a Swissvax lug brush, but I was never quit satisfied with it, it had the same failure problems over and over. The Ferrule on the Swissvax is plastic and breaks easily. Also, like most brushes, it would constantly shed its fibers and would start to deteriorate over time.
My first thoughts, it was much bigger than I expected. The handle and the bristles are larger/longer than any other brush I have ever used.
The bristles/handle are glued in with a load of epoxy, this ensures that you will not shed any bristles and it will be highly resistant to various chemicals
The bristles are made with Natural Boars Hair, this allows the brush to be used even on delicate surfaces without the fear of scratching the surface. There is a ridiculous amount of 'bristles' in this brush. They are packed in there extremely tight which makes it extremely dense.
The handle is very comfortable and easy to hold on to. It is contoured and it can be held with various grips depending where you are using it and how you need to hold it.
The length of the bristles and handle make it extremely easy and convenient to reach into areas where you could previously not reach or would scrape your knuckles getting to
I prefer to use this brush to clean the entire wheel. The problem I have with other wheel brushes or sponges is that you miss the tight areas of the wheel, which causes you to go back a second time to get the spots you missed. Again, the bristles on this brush are extremely dense and you can apply plenty of pressure to get aggressive and remove stubborn dirt/grime without having the bristles collapse in on themselves.
There is no sponge or mitt that will effectively clean 'tight' areas. If these areas are missed, they will completely stick out and take away from the overall clean look of the vehicle.
Finished
This is THE BEST Lug/Detail brush you will ever use. It is $24.95 which seems a little pricey compared to the Swissvax brush which is $13. But, this brush is far superior to any competitor. I went through (broke) 2 Swissvax brushes this year and 2 last year. This brush will pays for itself in quality alone, but take into account the years of service I will get out of this one brush and it is a great investment.
Mato
Finished
http://www.adamspolishes.com/p-537-adams-premium-trim-lug-nut-brush.aspx
Edited by MatoLink to comment
10 answers to this question
