Adam's Ultimate Fire Hose Nozzle & Shut Off Valve
Team Adam's
Fire Hose Nozzle - $49.95
Shut Off Valve - $19.95
Or Get Both for Just - $64.95
BOTH UNITS ARE 100% MADE IN THE USA!! :patriot:
ADAM'S ULTIMATE FIRE HOSE NOZZLE
Precision machined from a solid chunk of high quality 6061 T6 aluminum, then hard coated for corrosion resistance the Adam's Ultimate Fire Hose Nozzle will blow you away as its high pressure spray patterns blow dirt and soap effortlessly from your finish.
Featuring a flow rate of over 5 gallons per minute at just 40psi this is one powerful nozzle when you need it to be, but the spray can be adjusted to a wide fan for more delicate use. In a tight stream the pressure generated completely outpaces anything offered by our competitors, and with the solid aluminum construction and sidewalls 3/8" thick it will withstand years of use without ever getting bent, cracked, or damaged. This very well may be the last fire hose nozzle you ever buy!
The massive rubberized bumper and precision machined crosshatch milling makes sure it won't slip from your grip when things get soapy. We 110% guarantee that this nozzle will impress you just as much as it impresses us!!
SHUT-OFF VALVE
Sometimes its just about having the little things to make life easier, this is one of those things. If you're washing your car using a 50ft hose chances are the shut off is a good distance from where you're working. Adding a high quality shut-off valve to the end of the hose will allow you to control the water from where you're at, not where it starts!
Switching from one hose attachment to another? Simply flip the valve to off, swap attachments, and proceed without having to go anywhere.
Done hosing the car off? Conserve water and shut the flow off while you soap up the paint.
Don't want to search for the perfect setting on your fire hose nozzle each time? Use the valve to shut the water off instead of the twist action of the nozzle, that way each time you turn the valve on, the nozzle is set exactly how you want it!
100% high quality brass construction and made here, right in the USA, this is the alternative to the cheap, imported plastic shut off valves, sold at the big chain stores. 110% guaranteed to be the highest quality shut off valve you'll ever use!
  • Answers 61
  • Created
  • Last Reply
Thanks for the feedback Len. Thats very helpful to know since I don't have a well water scenario to test on.
The pressure is one thing and impressive. I think what makes me happier is the consistent, even spray pattern and the gradual transitions between each. So many cheapy nozzles out there will jump around from wide to narrow, spray uneven, or leak out at odd spots.
The pattern on this thing is pretty much perfect. Its even all the way thru the range and it transitions gradually between each. You can dial in an EXACT spray pattern easily and it will keep it there too.
The spray pattern is what impressed me the most. Like I said, I've used real fire hose nozzles and they have a steady transition from a high pressure fog to a steady stream, and like you say, many nozzles out there have uneven patterns that are almost impossible to get (and keep) the pattern you want. This is the only garden hose nozzle I've tried that has a consistent pattern throughout the whole range.
As a side note, I may have the same initials as the supplier that makes these nozzles, but am in no way affiliated with them (I was actually surprised when I saw "LDM Products" on the nozzle.) It's just my unbiased opinion when I say this is the best nozzle I've tried.
nice vid Ryan, this one looks like it works great..
the one I bought in the summer of 09 from AP is like the one you have from AG, I never really cared for it, not that great especially being called a FH nozzle, cant even compare it to what we use on the apparatus..
I might just have to get this one to replace it..
Just an update . I finally got to use mine yesterday . For anyone on the fence about this nozzle . Get it you will very happy this thing is awesome. Let me tell you I have other high priced nozzles and this one blows them flat out of the water. THanks Adam's for another quality american made product !!!!!!!!!
<object width="640" height="385"><param name="movie" value="
?fs=1&hl=en_US&rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=zSqzqyUFzTo?fs=1&hl=en_US&rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed></object>
I shot a quick video of the new fire hose nozzle for anyone on the fence.
So being a FF and now knowing this is made by an actual nozzle manufacturer.... I'm curious who. Chief, TFT, Akron?
Also, who waters there grass in December? I can't even see mine! :willy:
:iagree:
Must be nice wearing a t-shirt outside in December! :lolsmack:
Combining some threads here to eliminate confusion, thanks again Ryan for putting together a great video.
Anyone else have some insight about the nozzle... tons have shipped, although I suspect many of you are far too cold to think about using a hose outdoors right now LOL
This Fire Nozzle Rocks!! :rockon:I used mine a bunch of times now, it is very NICE.
Anyone on the fence about buying one, believe me you won't be sorry!
It might be freezing outside but it is warm in my garage!:D
Thanks Adam for another great detailing tool!:thumbsup:
