tjwhitford Posted May 13, 2011 Share Posted May 13, 2011 What's the best way to remove dealership decals without damaging your finish? Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 13, 2011 Share Posted May 13, 2011 Use a hair dryer a heat gun is too hot! Then wipe glue off with Goo Gone! Smart move I hate the look of them. Link to comment Share on other sites More sharing options...
mbreyer Posted June 7, 2011 Share Posted June 7, 2011 Ill pass on that wheel it looks rediculously bad for your paint. Just look at that guy try to control it and keep it from running up the door panel:lol: Link to comment Share on other sites More sharing options...
scott5 Posted June 7, 2011 Share Posted June 7, 2011 Yes..the 3M should work just fine. It's harsh so don't go rubbing it all over the place. Spray the line let it soak for a bit then wipe it off. That stuff takes off road tar so some post stripe adhesive should be easy. After its off I'd do a wash and wax for sure. Thanks.. Thats what i ended up doing. Cant even tell it was there! great product Link to comment Share on other sites More sharing options...
Osok Posted June 7, 2011 Share Posted June 7, 2011 We went and cant find goo gone anywhere, but found the 3M adhesive remover. Will this work to get all the stuff left after taking the pin stripe also Yes..the 3M should work just fine. It's harsh so don't go rubbing it all over the place. Spray the line let it soak for a bit then wipe it off. That stuff takes off road tar so some post stripe adhesive should be easy. After its off I'd do a wash and wax for sure. Link to comment Share on other sites More sharing options...
scott5 Posted June 6, 2011 Share Posted June 6, 2011 That was going to be my question as well... Decal, I use a thin plastic razor blade, while a badge I use fishing line and 3M adhesive remover, let soak and then remove. Chris We went and cant find goo gone anywhere, but found the 3M adhesive remover. Will this work to get all the stuff left after taking the pin stripe also Link to comment Share on other sites More sharing options...
joelr9801 Posted May 28, 2011 Share Posted May 28, 2011 For me personally, if I was at a dealer and they had their stickers on the back of a car I was about to purchase I would go to a differant dealer! I dont mind plate frames, I just throw them away anyways. You paid for the car why not let them pay for their own advertising.. BTW my dad used to own 2 new car dealers!! LOL Link to comment Share on other sites More sharing options...
Vincenzo Posted May 28, 2011 Share Posted May 28, 2011 That thing looks like it might scuff up your paint a bit. Might need to polish the area. Link to comment Share on other sites More sharing options...
scott5 Posted May 27, 2011 Share Posted May 27, 2011 What kind of care does the paint need after the eraser disk is used? Just washed again with some wax? Link to comment Share on other sites More sharing options...
rshadd Posted May 27, 2011 Share Posted May 27, 2011 <iframe width="425" height="349" src="http://www.youtube.com/embed/HHKN5_UfDik" frameborder="0" allowfullscreen></iframe> <iframe width="425" height="349" src="http://www.youtube.com/embed/SaflXzJSp_c" frameborder="0" allowfullscreen></iframe> Link to comment Share on other sites More sharing options...
scott5 Posted May 27, 2011 Share Posted May 27, 2011 3M Stripe Off Wheel (PN: 051131-07498). Makes removing decals and leftover adhesive easy. NAPA has them. Hows this work? Im getting ready to take the pin striping off my gfs cobalt ss. Link to comment Share on other sites More sharing options...
Oldman Cadillac Posted May 13, 2011 Share Posted May 13, 2011 I've taken off almost all of my decals/badges just like the guys have already said. That "Eraser" disc was great for removing my pin stripe. Made a mess but it was crazy fast and easy. Link to comment Share on other sites More sharing options...
shad2009 Posted May 13, 2011 Share Posted May 13, 2011 i'm gunna go out on a limb here for "safety" Heat Gun = Flex...Hair Dryer = PC lol welcome to the family...thanks for the reminder, i need to take mine off my stang Link to comment Share on other sites More sharing options...
Chewy Posted May 13, 2011 Share Posted May 13, 2011 stick on vinyl emblem or a badge ? That was going to be my question as well... Decal, I use a thin plastic razor blade, while a badge I use fishing line and 3M adhesive remover, let soak and then remove. Chris Link to comment Share on other sites More sharing options...
rshadd Posted May 13, 2011 Share Posted May 13, 2011 3M Stripe Off Wheel (PN: 051131-07498). Makes removing decals and leftover adhesive easy. NAPA has them. Link to comment Share on other sites More sharing options...
Bill-V8V Posted May 13, 2011 Share Posted May 13, 2011 stick on vinyl emblem or a badge ? Link to comment Share on other sites More sharing options...
BrianT Posted May 13, 2011 Share Posted May 13, 2011 Heat it for a 30 sec. and start pulling slowly and heat it as you go, should come right off! Welcome to the family!!!!! Link to comment Share on other sites More sharing options...
RedexInLA Posted May 13, 2011 Share Posted May 13, 2011 You can also use a hair dryer on low and work the area where the decal is. This option works if you are not comfortable using a high powered heat gun. Yes, much safer. I myself use a heat gun but not to long ago while removing a pin strip a little paint started to "bubble" and I've used heat guns many times. HG is unforgiving where a blow dryer is pretty much safe. Link to comment Share on other sites More sharing options...
that_low_cabi Posted May 13, 2011 Share Posted May 13, 2011 You can also use a hair dryer on low and work the area where the decal is. This option works if you are not comfortable using a high powered heat gun. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 13, 2011 Share Posted May 13, 2011 Heat gun to melt the glue, and a fishing line. Once the decals are removed, use goo goo gone or 3m adhesive remover to remove any access glue but I might suggest staying away from a heat gun, if you dont know what you are doing you can damage your paint.. on a nice hot day, or decent day at least, you can use fishing line or even floss.. once you get that off you can use the goo gone to remove what your fingers dont rub off.. and Welcome! Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted May 13, 2011 Share Posted May 13, 2011 Heat gun to melt the glue, and a fishing line. Once the decals are removed, use goo goo gone or 3m adhesive remover to remove any access glue Link to comment Share on other sites More sharing options...
tjwhitford
20 answers to this question
