musclejunkie Posted June 28, 2011 Share Posted June 28, 2011 I am going to attempt my first engine compartment detailing on the '11 Mustang. What are the do's and don'ts as far as what areas to protect with a baggie and not get wet? I'm going to use 50/50 APC and Boars Hair brush. Thanks amigos. Quote Link to comment Share on other sites More sharing options...
0 Chewy Posted June 28, 2011 Share Posted June 28, 2011 Don't spray water directly at and under pressure at electronic components. If you have an open element air filter then cover it. How dirty is it? I use a spray bottle of car shampoo and water to clean mine. If they're greasy, then APC is great! I did my P/U truck and covered nothing. Quote Link to comment Share on other sites More sharing options...
0 musclejunkie Posted June 28, 2011 Author Share Posted June 28, 2011 It isn't too bad - just mostly road dust. Maybe the blaster would be a better alternative? In Adam's video #6 he says the new cars aren't as bad as the older cars. I'm just a little paranoid about spraying water around in the engine compartment. I also know enough not to spray a hot engine. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 28, 2011 Share Posted June 28, 2011 If its just dusty cover up areas like Christopher said, hose off & blow dry with air (I use my Master Blaster) then all you may need is DS.I f the DS don't get it then I would use APC. After wiping down with DS go over with SVRT and In & Out Spray! Quote Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 28, 2011 Share Posted June 28, 2011 Just don't use high pressure and your fine. A little aluminum foil or plastic bags to cover open element filters, battery terminals, or other things that might be sensitive to water and you're good to go. Modern engine bays really aren't all that susceptible to water related issues. <iframe width="853" height="510" src="http://www.youtube.com/embed/JdHX_wPUKZI?rel=0" frameborder="0" allowfullscreen></iframe> Quote Link to comment Share on other sites More sharing options...
0 Chewy Posted June 28, 2011 Share Posted June 28, 2011 Do NOT use the aluminum foil on a battery. I know that sounds like a stupid thing to say, but there are people out there that would do it!!!! I don't blow dry my engines for fear of driving water somewhere, but if you're careful around the engine area, it'd work great. Quote Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted June 28, 2011 Share Posted June 28, 2011 Do NOT use the aluminum foil on a battery. I know that sounds like a stupid thing to say, but there are people out there that would do it!!!! I don't blow dry my engines for fear of driving water somewhere, but if you're careful around the engine area, it'd work great. I always dry with the Master Blaster, so far never a problem! Quote Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 28, 2011 Share Posted June 28, 2011 Do NOT use the aluminum foil on a battery. I know that sounds like a stupid thing to say, but there are people out there that would do it!!!! I don't blow dry my engines for fear of driving water somewhere, but if you're careful around the engine area, it'd work great. LOL... yea, sorry... should have worded that better. Quote Link to comment Share on other sites More sharing options...
0 musclejunkie Posted June 28, 2011 Author Share Posted June 28, 2011 Thanks! Great video. Quote Link to comment Share on other sites More sharing options...
0 Redvenm Posted June 28, 2011 Share Posted June 28, 2011 I spray down the engine lightly with water in my 2010 F150 just to get wet. Spray APC where needed, fpray off using fire hose nozzle but certainly not at high pressure. Finish off with SVRT and In & Out where needed. very simple, I don't cover anything. Quote Link to comment Share on other sites More sharing options...
0 Paul Mitchell Posted June 29, 2011 Share Posted June 29, 2011 Your Mustang Owner's Manual will show you exactly what you need to cover prior to washing the engine compartment. It's under the heading "Cleaning". If you don't have the manual handy you can download it off the internet. Quote Link to comment Share on other sites More sharing options...
0 MAYBEN Posted June 29, 2011 Share Posted June 29, 2011 Foil on a battery, why not? Quote Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted June 29, 2011 Share Posted June 29, 2011 Foil on a battery, why not? And wear your wedding ring while doing it Quote Link to comment Share on other sites More sharing options...
0 texn884 Posted June 29, 2011 Share Posted June 29, 2011 Look at my post under engine compartment after 80,000 miles. I foamed the engine closed the hood and washed the rest of the car then rinsed the engine off then detailed it. Because Race Car! Quote Link to comment Share on other sites More sharing options...
0 MAYBEN Posted June 29, 2011 Share Posted June 29, 2011 And wear your wedding ring while doing it you know it! Quote Link to comment Share on other sites More sharing options...
0 texn884 Posted June 29, 2011 Share Posted June 29, 2011 Zapppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppp Quote Link to comment Share on other sites More sharing options...
0 Chewy Posted June 29, 2011 Share Posted June 29, 2011 I never cover the battery in the G8 when washing the engine... Quote Link to comment Share on other sites More sharing options...
0 texn884 Posted June 29, 2011 Share Posted June 29, 2011 Me either since it is in the trunk hideing Quote Link to comment Share on other sites More sharing options...
0 musclejunkie Posted June 29, 2011 Author Share Posted June 29, 2011 Your Mustang Owner's Manual will show you exactly what you need to cover prior to washing the engine compartment. It's under the heading "Cleaning". If you don't have the manual handy you can download it off the internet. Thanks! They actually have some good engine compartment cleaning info in the manual! Quote Link to comment Share on other sites More sharing options...
0 BlueGenCoupe Posted June 29, 2011 Share Posted June 29, 2011 I normally, cover any filters or electronic devices. Lightly mist the engine bay with water, sprits down with APC, scrub it down, lightly rinse off the water. I then Start the car, and let it sit idleing for 15 20 mins while I wash the rest of the car. If its not really dirty and your affraid of ruining sumthing, use waterless wash Quote Link to comment Share on other sites More sharing options...
0 jpu471 Posted June 30, 2011 Share Posted June 30, 2011 Too late Dylan IM ALIVE IM ALIVE zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz Quote Link to comment Share on other sites More sharing options...
0 musclejunkie Posted June 30, 2011 Author Share Posted June 30, 2011 I'm a little concerned about using APC in my engine compartment. There are a lot of painted surfaces (APC is not good for paint) and the block is aluminum. I don't think APC is good on aluminum either. Maybe a 50/50 dilution would be safer, but still worried the aluminum could turn black. Should I just foam it with Adam's Shampoo then hit it with the boars hair and a light rinse? Sorry to turn this into a science project. Quote Link to comment Share on other sites More sharing options...
0 Chewy Posted June 30, 2011 Share Posted June 30, 2011 If it's not greasy, use the shampoo like I stated above! Chris Quote Link to comment Share on other sites More sharing options...
0 Vincenzo Posted July 6, 2011 Share Posted July 6, 2011 When I washed my 06 mustang's engine compartment, I just cover up the fuse box, CAI, and battery. Quote Link to comment Share on other sites More sharing options...
0 sparg93 Posted July 7, 2011 Share Posted July 7, 2011 what is APC? Quote Link to comment Share on other sites More sharing options...
0 mc2hill Posted July 7, 2011 Share Posted July 7, 2011 what is APC? All Purpose Cleaner. Quote Link to comment Share on other sites More sharing options...
musclejunkie
32 answers to this question
