I just got a phone call from a customer and at the same time saw a post with a member asking how long to let polish dry before it can be removed. Both great questions and I think it's probably a common concern that most have.
Polish, either our Revive Polish, Swirl and Haze Remover, or Fine Machine Polish - even our Metal Polish 1 and 2 - have ZERO dry time. They are not products that need to cure or form a protective layer and therefore can be removed after application. We still made them dustless so when they are removed you shouldn't be plagued with dust all over your hard work.
All of our polishes however should be used till they can't be seen any longer - that's part of "working them in." You'll want to use our Revive, Fine Machine Polish, and Swirl and Haze Remover till they've gone completely clear on your paint or clear coat. That's when they've been broken down and you can move on to your next body panel. Will that take a long time? Potentially, but remember it's all about patience, pressure, and practice!
Team Adam's
24 answers to this question
