LQ9SS Posted August 13, 2011 Share Posted August 13, 2011 Does anyone use just SHR and not follow will the FMP? I know you won't get near the results if you do use the FMP after, but I am detailing a friends 09 silver impala and am not going for perfection, just want to remove some minor swirls/scratches. Link to comment Share on other sites More sharing options...
Stryker Posted August 13, 2011 Share Posted August 13, 2011 You kins of answered your own question. You won't get the best results but I would imagine you would see a decent improvement. I would just be concerned about the micro marring that the SHR would cause and how bad that might be visible in the daylight. Link to comment Share on other sites More sharing options...
crowvet Posted August 13, 2011 Share Posted August 13, 2011 I did that when I did my motorhome, it was just to dang big. I apllied a coat of Americana and am totally happy with the results. Link to comment Share on other sites More sharing options...
LQ9SS Posted August 13, 2011 Author Share Posted August 13, 2011 Also, i know the car will be ran through car washes, but he want's it done anyways, so I am not too concerned about the marring left behind from the SHR. Link to comment Share on other sites More sharing options...
Chris@Adams Posted August 13, 2011 Share Posted August 13, 2011 Does anyone use just SHR and not follow will the FMP? I know you won't get near the results if you do use the FMP after, but I am detailing a friends 09 silver impala and am not going for perfection, just want to remove some minor swirls/scratches. The SHR will remove scratches but it will leave real fine marring & cloudiness that the FMP will remove, so yes you need to use FMP after. Link to comment Share on other sites More sharing options...
Doug123 Posted August 13, 2011 Share Posted August 13, 2011 If you had to do only one polish, go with the FMP. As said above, the SHR will leave a kind of cloudiness (micro marring) on the finish Link to comment Share on other sites More sharing options...
green6767 Posted August 13, 2011 Share Posted August 13, 2011 Kind of sounds like covering up one problem with a lesser problem by only using SHR. I agree, if you're only going to use one polish then use the FMP....but you probably won't see removal of all the swirls. Link to comment Share on other sites More sharing options...
Bill-V8V Posted August 13, 2011 Share Posted August 13, 2011 I agree, just use the FMP Link to comment Share on other sites More sharing options...
randyfox Posted August 14, 2011 Share Posted August 14, 2011 Kind of sounds like covering up one problem with a lesser problem by only using SHR. My thoughts exactly. Link to comment Share on other sites More sharing options...
LQ9SS Posted August 14, 2011 Author Share Posted August 14, 2011 I agree, just use the FMP Does the FMP have the capability of removes minor swirls/scratces. I am using the Flex btw... Also, can you use the FMP with the orange pad? would it give the polish more cutting capabilities? Link to comment Share on other sites More sharing options...
Bill-V8V Posted August 14, 2011 Share Posted August 14, 2011 Does the FMP have the capability of removes minor swirls/scratces. I am using the Flex btw... Also, can you use the FMP with the orange pad? would it give the polish more cutting capabilities? The FMP with White pad will do a great job on minor swirls and scratches especially with a Flex. I've done entire paint corrections with just FMP cause I ran out of SHR, it just takes a few more passes Link to comment Share on other sites More sharing options...
LQ9SS Posted August 14, 2011 Author Share Posted August 14, 2011 The FMP with White pad will do a great job on minor swirls and scratches especially with a Flex. I've done entire paint corrections with just FMP cause I ran out of SHR, it just takes a few more passes Thanks Bill, you are always great help:thumbsup: Link to comment Share on other sites More sharing options...
Perez Posted August 14, 2011 Share Posted August 14, 2011 I have also done corrections with just fmp it will get the job done right for your application. Link to comment Share on other sites More sharing options...
LQ9SS
12 answers to this question
