paoutdoorsman Posted January 12, 2012 Share Posted January 12, 2012 Looks like a great project! I'd love to be turning wrenches on that new shiny hardware. Link to comment Share on other sites More sharing options...
rimalm Posted January 12, 2012 Share Posted January 12, 2012 Very Nice! You should have no problems making your goals! Link to comment Share on other sites More sharing options...
AZGTO Posted January 19, 2012 Author Share Posted January 19, 2012 Some Pictures of the Install so far! Before Taking it apart: Crank Pulley was being a pain..But I finally got it off And the cam For now I just have some cleaning to do on the drivers side cylinder deck and then I am just waiting for the rest of my parts to get in so I can continue with the install Link to comment Share on other sites More sharing options...
Wardo Posted January 19, 2012 Share Posted January 19, 2012 Keep working hard until its ready. I'll be waiting to drive it.... Link to comment Share on other sites More sharing options...
zxgto06 Posted January 19, 2012 Share Posted January 19, 2012 Looks awesome man! Link to comment Share on other sites More sharing options...
BrianT Posted January 19, 2012 Share Posted January 19, 2012 Looks great! Keep up the good work!! Link to comment Share on other sites More sharing options...
rimalm Posted January 19, 2012 Share Posted January 19, 2012 Good stuff man! Link to comment Share on other sites More sharing options...
paoutdoorsman Posted January 19, 2012 Share Posted January 19, 2012 Link to comment Share on other sites More sharing options...
AZGTO Posted January 20, 2012 Author Share Posted January 20, 2012 Made some progress today! Most of the parts came in, just waiting on lifters now Got the new cam in, new timing chain in, and the most time consuming step today was installing the new melling oil pump. HUGE pain in the neck, but I finally got it all in. Tomorrow I will bolt up the timing cover and install the crank pulley, from there I will wait till the lifters come in! Link to comment Share on other sites More sharing options...
Team Adam's Posted January 20, 2012 Share Posted January 20, 2012 You're making good progress! Pro tip: Put your pulley in the oven @ 250* for 30 minutes before you try to install it. 60% of the time, it works every time. Link to comment Share on other sites More sharing options...
AZGTO Posted January 24, 2012 Author Share Posted January 24, 2012 So I did some reading and found out that the Red Spring that comes installed in the Melling Oil Pumps is not ideal for stock internal engines since it is a high pressure spring. So since I hadn't yet bolted up the front cover I decided it was best to swap the spring to the Blue Spring, which is stock oil pressure. Had to lower the oil pan again, pull the oil pump out completely and then swap the spring. I got the oil pump bolted back in and the oil pan bolted back up, so now I am back to looking like this Tomorrow I plan on bolting up the front cover and installing the crank pulley, from there I am still waiting on the lifters, once the lifters come in then I can continue the rest of the work up top! Link to comment Share on other sites More sharing options...
Team Adam's Posted January 24, 2012 Share Posted January 24, 2012 Good choice on the blue spring. The red is not for any streetable motor, WAY too much oil pressure. I ran a ported LS6 pump with my build and I saw ~70psi at cold start and ~40psi warm cruising. Link to comment Share on other sites More sharing options...
ssbusdrvr Posted January 24, 2012 Share Posted January 24, 2012 Looks great! Keep up the good work!! <!-- / message --> +1 Have to check out this section more often, Link to comment Share on other sites More sharing options...
AZGTO Posted January 25, 2012 Author Share Posted January 25, 2012 Made some more progress tonight Bolted up the front timing cover and installed the crank pulley The lifters should be in any day now and from there I can measure my PTV clearance and measure the pushrod length. Hoping I don't have to flycut the pistons! Link to comment Share on other sites More sharing options...
AZGTO Posted March 24, 2012 Author Share Posted March 24, 2012 Top Gear Motorsports Finished up everything on the GTO once I found out the pistons needed to be flycut. Top Gear did an amazing job on the car and I highly recommend anyone that needs any work done to give Sean a call and he will get you taken care of. Here are the final pictures from the rest of the work that was done: Flycutting Heads were finally mounted on: and how it looks now: Dyno results and vids can be found here: http://www.adamsforums.com/forums/vehicle-mods/16781.htm#post291425 Link to comment Share on other sites More sharing options...
