Chobbs Posted October 19, 2011 Posted October 19, 2011 Are there any special considerations I need to adhere to when cleaning this wash pad? Has any one had one long enough to go through several washes? How does your wool pad look? Can/should it be brushed out?? Any help is appreciated. Sent from my iPhone using Tapatalk
ArmyAcadia09 Posted October 19, 2011 Posted October 19, 2011 aye! there is a thread on here about clearcoat issues on a camaro using focus pads. EDIT here ya go http://www.adamsforums.com/forums/machine-polishing/14165.htm
Chobbs Posted October 22, 2011 Author Posted October 22, 2011 Guess I'll find out today when I clean it. Sent from my iPhone using Tapatalk
Chobbs Posted October 22, 2011 Author Posted October 22, 2011 Is it bad to let the wool mitt soak over night???
Jeebalow Posted October 21, 2011 Posted October 21, 2011 The merino wool pad, which is a mitt. Sent from my iPhone using Tapatalk
07RS4 Posted October 21, 2011 Posted October 21, 2011 Are you guys talking about de-oiling the wash pad? or mitt? The wash pad is synthetic, soooooooo.......
Chobbs Posted October 21, 2011 Author Posted October 21, 2011 damn i ran mine at 6 DOH Your focus pads??? Did you have any issues? Sent from my iPhone using Tapatalk
Team Adam's Posted October 20, 2011 Posted October 20, 2011 Thanks Dylan! That make me feel much better! I will from now on use the 4" focus pads on a speed of 4. 4"=4 speed. Amazingly simple. I was worried because I somehow forgot that ratio and did the entire pc correction (including focus pad part) on a setting of 5. Sent from my iPhone using Tapatalk No problem. When in doubt, the videos are your friend: <iframe width="640" height="360" src="http://www.youtube.com/embed/cdPKQ_BjJkw?feature=player_embedded" frameborder="0" allowfullscreen></iframe>
Chobbs Posted October 20, 2011 Author Posted October 20, 2011 Thanks Dylan! That make me feel much better! I will from now on use the 4" focus pads on a speed of 4. 4"=4 speed. Amazingly simple. I was worried because I somehow forgot that ratio and did the entire pc correction (including focus pad part) on a setting of 5. Sent from my iPhone using Tapatalk
Team Adam's Posted October 20, 2011 Posted October 20, 2011 We specifically do not condone the use of the focus pads at anything above speed 4. Its unnecessarily tough on the pads, backing plate, and machine... stick to speed 4 when using the smaller pads on the PC. As far as strike thru with the PC.... it would take a ton (hundreds of passes) and/or a very thin paint job to have that concern. The PC simply doesn't remove enough material with a pass to have that concern.
Chobbs Posted October 20, 2011 Author Posted October 20, 2011 Thanks. I had already read that thread. And there is some talk of the PC, but He was using the focus pads with a drill essentially creating a rotary polisher. My question is specifically about using the focus pads with the PC, non forced rotation, at a setting of 5 Sent from my iPhone using Tapatalk
Chobbs Posted October 19, 2011 Author Posted October 19, 2011 Thanks for all the replies! I just finished a twelve hour detail last weekend and plan on washing and putting a second coat of Americana on this weekend. I've used the wool mitt once washed by hand and let dry(loved how the mitt felt when wet). I am hoping this new mitt is going to help me prevent as many micro scratches as possible. On another note. (not sure if this should be in a new thread)...is it possible to strike through the clearcoat using the 4" focus pads on the PC with a setting of 5? I don't have any issues but worry if I go over the same spot next time with the focus pads that I'll be making the clearcoat too thin. This camaro has a few areas that I prefer to use the focus pads because of all the curves. Should I be worried that I used the setting of 5 instead of 4 on the PC? Sent from my iPhone using Tapatalk
Team Adam's Posted October 19, 2011 Posted October 19, 2011 Since the wool comes from a natural source (sheep) the consistency of the oil in the wool will vary a great deal. Some would benefit from a soaking in APC right away, others it won't matter. If you notice yours not sudsing very much after the first use, a soaking in a bucket with APC and rinsing will help remove those oils and help the mit perform as designed.
goodmanXX3 Posted October 19, 2011 Posted October 19, 2011 around the 4th time using it, it suds up like a wash pad. ...Fourth wash really really made me smile. Its not mandatory to de oil it or even suggested. But its something I was informed of and am just sharing knowledge. I love the wash pads too.
THE Mook Posted October 19, 2011 Posted October 19, 2011 I found out about de oiling it too late. I had higher expectations than most with this...as I LOVE OUR CURRENT WASH PADS....but yeah I noticed mine had a decent amount of oils...Fourth wash really really made me smile. Its not mandatory to de oil it or even suggested. But its something I was informed of and am just sharing knowledge.
02Xtreme07ss Posted October 19, 2011 Posted October 19, 2011 I used mine out of the box too. Worked great. I have brushed it once with a dog grooming brush I picked up from the local pet shop and it's as good as new...all nice and fluffy.
Chris@Adams Posted October 19, 2011 Posted October 19, 2011 I used my out of the box, I have used it a bunch of times. When I done I wash it out good in the sink and hang up to dry. No problems it works great!
ArmyAcadia09 Posted October 19, 2011 Posted October 19, 2011 I will say you need to soak it in All Purpose Cleaner and water for a little bit to help extract the oils from the natural animal hair. I didn't before I started using mine, and until they wore out or washed out, I thought I had a broken, dead sheep. so you're saying to do this before the first wash?
goodmanXX3 Posted October 19, 2011 Posted October 19, 2011 I will say you need to soak it in APC and water for a little bit to help extract the oils from the natural animal hair. I didn't before I started using mine, and until they wore out or washed out, I thought I had a broken, dead sheep. B-aa-aaa-aa-aaa-ad. is that right? i started using mine straight out the box and did not like it (at first), it didn't sud up as much as the wash pads. but i kept using it, gave it another chance and now around the 4th time using it, it suds up like a wash pad.
THE Mook Posted October 19, 2011 Posted October 19, 2011 I haven't brushed mine out. I am about 13-14 washes in now on mine. Still working good, hairfibers still in tact, no dreadlocking. I clean mine just like I clean the other pads...on top of the bucket over the Grit Guard...just like Dylan shows. Mook I will say you need to soak it in APC and water for a little bit to help extract the oils from the natural animal hair. I didn't before I started using mine, and until they wore out or washed out, I thought I had a broken, dead sheep. B-aa-aaa-aa-aaa-ad.
Chobbs
23 answers to this question
