can't mark forum read from quick links
WildBillsBlueC6
Posted
When I try to use the quick like I get this message :confused:
"Your submission could not be processed because a security token was invalid.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error."
Bill
Posted
If it started out as pre-3.8.5 that same token issue will result because your template would have begun life before the new security token was added. You'll notice that the mark read at the bottom of the forums has the markreadhash variable defined in it with the relevant value afterward but the mark read in the quick links does not; that's due to the missing markreadhash=$bbuserinfo[securitytoken] in the template which that article mentions.
