egott_91 Posted January 16, 2012 Share Posted January 16, 2012 I was thinking about this on my way home. It would be rather expensive but I wonder how it would work or possibly adding it to the tank with another washer fluid. Discuss. Link to comment Share on other sites More sharing options...
DaveVY Posted January 16, 2012 Share Posted January 16, 2012 There is an actual glass sealant product. I ordered some up recently, but haven't had a chance to try it. I wonder which product would work better? I can see where the spray sealant would be easier to apply. Or maybe not. In reading the product description it says it is in a 4 oz fine mist spray. But the pic appeared to look as though it were a flip top lid. I haven't even opened the box yet. The glass sealant is a great product. It does have a flip top lid and is applied using a blue microfiber applicator. It takes very very little product for an application and it works great! The windshield needs to be clean before applying the sealant. I remove all the old product first using APC, then will clay, use the glass cleaner, then apply the sealant. After the sealant hazes then use the glass cleaner to remove the haze. I can't give a good comparison to other products because I hadn't used them in over a decade but will say that I love this product as it seems to me that it lasts longer than I recall those others lasting. Link to comment Share on other sites More sharing options...
Chuckkilo3 Posted January 23, 2012 Share Posted January 23, 2012 In order to prevent freezing there has to be a fair amount of alcohol content, if we did that it wouldn't be safe for window tint on the interior so you're talking about another product all together. Personally I avoid using my wiper fluid at all costs.... so long as you keep your blades in good shape, a good coating of sealant on the glass, and don't let the buildup get too bad that need for washer fluid becomes somewhat limited save for unusual circumstances, not to mention its just horribly messy. Come to the southern US when the bugs are out in full force. You will use plenty of washer fluid. I don't worry about freezing. I only worry about that if I am going to drive up north during the winter and I avoid that at all costs. Link to comment Share on other sites More sharing options...
egott_91 Posted January 23, 2012 Author Share Posted January 23, 2012 In order to prevent freezing there has to be a fair amount of alcohol content, if we did that it wouldn't be safe for window tint on the interior so you're talking about another product all together. Personally I avoid using my wiper fluid at all costs.... so long as you keep your blades in good shape, a good coating of sealant on the glass, and don't let the buildup get too bad that need for washer fluid becomes somewhat limited save for unusual circumstances, not to mention its just horribly messy. Come to Indiana in the winter and try to not use washer fluid! Link to comment Share on other sites More sharing options...
Team Adam's Posted January 23, 2012 Share Posted January 23, 2012 In order to prevent freezing there has to be a fair amount of alcohol content, if we did that it wouldn't be safe for window tint on the interior so you're talking about another product all together. Personally I avoid using my wiper fluid at all costs.... so long as you keep your blades in good shape, a good coating of sealant on the glass, and don't let the buildup get too bad that need for washer fluid becomes somewhat limited save for unusual circumstances, not to mention its just horribly messy. Link to comment Share on other sites More sharing options...
Chuckkilo3 Posted January 22, 2012 Share Posted January 22, 2012 How about some Adam's brand windshield washer tablets? Make them some other color than blue and add a nice smell to it. I currently use 303 tablets. It would work well for use that live in areas where it rarely freezes. Link to comment Share on other sites More sharing options...
NYMisano Posted January 17, 2012 Share Posted January 17, 2012 I can attest that Adams Glass Sealant works FAR better then the old standby competing product. Lasts way longer (no comparison here), works better, and does not cause wiper chatter. Link to comment Share on other sites More sharing options...
SLOWpoke Posted January 16, 2012 Share Posted January 16, 2012 Adam's Glass Sealant has 4x (at least) the active ingredient as what can be found in Rain-X. Quick Sealant works better on anything not glass. Glass Cleaner in the washer tank will freeze, and yes, in extreme heat, will degrade it's effectiveness. Mook And theres our answer! Thanks Mook! Link to comment Share on other sites More sharing options...
THE Mook Posted January 16, 2012 Share Posted January 16, 2012 Adam's Glass Sealant has 4x (at least) the active ingredient as what can be found in Rain-X. Quick Sealant works better on anything not glass. Glass Cleaner in the washer tank will freeze, and yes, in extreme heat, will degrade it's effectiveness. Mook Link to comment Share on other sites More sharing options...
egott_91 Posted January 16, 2012 Author Share Posted January 16, 2012 It would probably freeze. In the winter, yes. In the summer, I'm thinking the heat and everything would hurt the product and not make it as effective. So I guess it's not a great idea. Lol. I could see maybe mixing it with another fluid, but really that's just a waste of money. Link to comment Share on other sites More sharing options...
crowvet Posted January 16, 2012 Share Posted January 16, 2012 It would probably freeze. Link to comment Share on other sites More sharing options...
SLOWpoke Posted January 16, 2012 Share Posted January 16, 2012 There is an actual glass sealant product. I ordered some up recently, but haven't had a chance to try it. I wonder which product would work better? I can see where the spray sealant would be easier to apply. Yep there is!!! Though I can't comment on which is better etc, thats one of the FEW products Adams offers that I haven't ordered or used yet So again I can't comment on its ability or durability. Other products on my list to get: Undercarriage spray (used it but haven't bought my own YET, semi unpractical for me as virtually zero wheel gap) so its a luxury rather than a must Fender brush (again same reasons as above) Lug nut brush (really want this one!!!) Glass sealant (as mentioned) Turbo Stick (wheels stay clean anyways, however I'm getting for customers/friends cars) Americana (going in the next order ) CANNOT WAIT to complete my line up!!! Along with a Flex Really curious about the real world application of the spray sealant OR glass sealant in place of a rain x type of product Link to comment Share on other sites More sharing options...
LFairbanks Posted January 16, 2012 Share Posted January 16, 2012 I'm using the spray sealant instead of rain x and after glass cleaner...of course I have to say I have NO clue how it does in the rain as I don't drive the car I use it on if its raining but it def beads up during washing so probably work pretty well to repel the rain! Can others chime in with a more "real world" result? There is an actual glass sealant product. I ordered some up recently, but haven't had a chance to try it. I wonder which product would work better? I can see where the spray sealant would be easier to apply. Or maybe not. In reading the product description it says it is in a 4 oz fine mist spray. But the pic appeared to look as though it were a flip top lid. I haven't even opened the box yet. Link to comment Share on other sites More sharing options...
SLOWpoke Posted January 16, 2012 Share Posted January 16, 2012 I'm using the spray sealant instead of rain x and after glass cleaner...of course I have to say I have NO clue how it does in the rain as I don't drive the car I use it on if its raining but it def beads up during washing so probably work pretty well to repel the rain! Can others chime in with a more "real world" result? Link to comment Share on other sites More sharing options...
BlazinSS934 Posted January 16, 2012 Share Posted January 16, 2012 I think a good product that needs to come to market is a rain x type of washer fluid but clear I hate using rain x fluid because it drys orange all over the car Link to comment Share on other sites More sharing options...
jimboman Posted January 16, 2012 Share Posted January 16, 2012 I think its been asked before, but it would not handle under hood heat well, also ot needs to be buffed off. Link to comment Share on other sites More sharing options...
LFairbanks Posted January 16, 2012 Share Posted January 16, 2012 It would probably freeze. Link to comment Share on other sites More sharing options...
the1inblue Posted January 16, 2012 Share Posted January 16, 2012 Lol not on my budget Sent from my DROID BIONIC using Tapatalk Link to comment Share on other sites More sharing options...
egott_91
17 answers to this question
