Fit08 Posted April 25, 2012 Share Posted April 25, 2012 Just curious, anyone using a separate clay bar for the lower portions of the car say most likely below the door bottom OR are we even claying this area. This is a DD application. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted April 25, 2012 Share Posted April 25, 2012 I use one. No point in using 2. If Any damage is done to the car while claying, its going to be removed while polishing Link to comment Share on other sites More sharing options...
Adamized Posted April 25, 2012 Share Posted April 25, 2012 I use half of one for the whole car. Link to comment Share on other sites More sharing options...
Kustom_FX Posted April 25, 2012 Share Posted April 25, 2012 I have 4.. 2 for the body, upper and lower, 1 for the glass, and 1 for the wheels. I took a silver sharpie and labeled them all. Its overkill for sure, but I like it that way. I also tarp the ground before I start as well, I have a nasty habit of dropping it, and that gets expensive! Link to comment Share on other sites More sharing options...
07RS4 Posted April 25, 2012 Share Posted April 25, 2012 I use one. No point in using 2. If Any damage is done to the car while claying, its going to be removed while polishing +1. KIS - Keep It Simple EDIT: Quick tip: Use a bucket of warm/hot water...let your clay soak in before/during the process....it will make it much easier to work. Link to comment Share on other sites More sharing options...
dipolley Posted April 25, 2012 Share Posted April 25, 2012 I use 1/3 of 1 bar for a detail. And I get 4-5 uses out of that. Rub, fold, flatten, repeat. Link to comment Share on other sites More sharing options...
Kingsford Posted April 25, 2012 Share Posted April 25, 2012 I have 2.... one for paint, one for wheels. Link to comment Share on other sites More sharing options...
ChargerMatt Posted April 25, 2012 Share Posted April 25, 2012 I have 2.... one for paint, one for wheels. Link to comment Share on other sites More sharing options...
Captain Slow Posted April 26, 2012 Share Posted April 26, 2012 I also tarp the ground before I start as well, I have a nasty habit of dropping it, and that gets expensive! Same here. Mr Bungles, that's me, frequently drops the clay bar so I put down an old bed sheet. It's saved me several clay bars over the years. Link to comment Share on other sites More sharing options...
b_pappy Posted April 26, 2012 Share Posted April 26, 2012 I keep an older one handy for the rougher spots. Bruce Link to comment Share on other sites More sharing options...
Skywalker Posted April 26, 2012 Share Posted April 26, 2012 I have a 200g bar that I pull a small portion of. I also let it soak in warm water mixed with ONR to soften it. I always wear a nitrile/latex glove on the hand I clay with as well, which helps a lot with gripping the clay. There are latex food service gloves that are very textured and work very well for handling clay. Link to comment Share on other sites More sharing options...
gymrat7953 Posted April 27, 2012 Share Posted April 27, 2012 I have 4.. 2 for the body, upper and lower, 1 for the glass, and 1 for the wheels. I took a silver sharpie and labeled them all. Its overkill for sure, but I like it that way. I also tarp the ground before I start as well, I have a nasty habit of dropping it, and that gets expensive! Me too. Link to comment Share on other sites More sharing options...
MichiganSRT8 Posted April 27, 2012 Share Posted April 27, 2012 make sure you rip that bar apart, one bar last a long time for me. proper kneading is very important, getting that turned over and you will get it to last a long time. That being said, if your worried at all keep one little for upper body, one for lower and once for glass. Really no need unless your never flipping the clay, which could turn out very bad hah. Link to comment Share on other sites More sharing options...
Fit08
12 answers to this question
