1sikss Posted February 25, 2013 Share Posted February 25, 2013 will the machine super sealant work on wheels... and if so how well does it work on wheels and what kind of wheels... Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted February 25, 2013 Share Posted February 25, 2013 It is easiest to use Quick Sealant on your wheels! Adam's Quick Sealant Link to comment Share on other sites More sharing options...
0 Blazer15 Posted February 25, 2013 Share Posted February 25, 2013 Agree with Chris. I use QS on my wheels and it works great. Link to comment Share on other sites More sharing options...
0 Tim Posted February 25, 2013 Share Posted February 25, 2013 It is easiest to use Quick Sealant on your wheels! Adam's Quick Sealant What if your wheels are nice and clean and in your basement? Link to comment Share on other sites More sharing options...
0 paoutdoorsman Posted February 25, 2013 Share Posted February 25, 2013 For those who have been using quick sealant on your wheels... do you worry about QS oversray on the tires? And would that affect the application of SVRT? Link to comment Share on other sites More sharing options...
0 goheels Posted February 25, 2013 Share Posted February 25, 2013 I use mss on my wheels with absolutely fantastic long lasting results. While I'm sure I'm overreacting, I don't like he idea of breathing in spray from the aerosol in an enclosed garage. But, either way you can't go wrong. Link to comment Share on other sites More sharing options...
0 JBlack151 Posted February 25, 2013 Share Posted February 25, 2013 For those who have been using quick sealant on your wheels... do you worry about QS oversray on the tires? And would that affect the application of SVRT? No worrying here. I like to apply the majority of the wheels by using the Ameircana applicator. For the areas that are a little bit harder to reach then I may spray directly onto the wheels. For the most part no overspray is reaching the tires during this process. If you go this route, remember to use an extra applicator for your wheels so you keep one designated for paint and one for wheels. You can label each with a marker. Link to comment Share on other sites More sharing options...
0 ECaulk Posted February 25, 2013 Share Posted February 25, 2013 I use mss on my wheels with absolutely fantastic long lasting results. While I'm sure I'm overreacting, I don't like he idea of breathing in spray from the aerosol in an enclosed garage. But, either way you can't go wrong. You should always use aerosols in well ventaliated areas, enclosed garages do not meet the well ventaliated areas, opening a garage door and the use of a box fan or two will create a well ventaliated area (box fans not required they just help move more air,also outside works too). Link to comment Share on other sites More sharing options...
0 DaveVY Posted February 25, 2013 Share Posted February 25, 2013 For those who have been using quick sealant on your wheels... do you worry about QS oversray on the tires? And would that affect the application of SVRT? I use the SVRT before the sealant, so then any overspray from the wheel is on top of the SVRT and I don't need to be concerned about a change of appearance. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted February 25, 2013 Share Posted February 25, 2013 What if your wheels are nice and clean and in your basement? Give them a shot anyway....... Link to comment Share on other sites More sharing options...
0 BluedogGMC Posted March 10, 2013 Share Posted March 10, 2013 Since I already have the Machine Super Sealant would it be OK to use it on the wheels while I have them off of the truck for rotation. That way I could use an applicator around the back inside of the rim. The question is, Is the Machine Sealant basically the same as the Quick Sealant just in a liquids form? Link to comment Share on other sites More sharing options...
0 mc2hill Posted March 10, 2013 Share Posted March 10, 2013 Since I already have the Machine Super Sealant would it be OK to use it on the wheels while I have them off of the truck for rotation. That way I could use an applicator around the back inside of the rim. The question is, Is the Machine Sealant basically the same as the Quick Sealant just in a liquids form? The trick is to put on a very, very thin coat. Too thick and it will be a lot of work to remove. Link to comment Share on other sites More sharing options...
0 Z71_Denali Posted March 11, 2013 Share Posted March 11, 2013 i used to use MSS hand applied with a microfiber pad, but since getting QS, its much easier to use! Link to comment Share on other sites More sharing options...
1sikss
12 answers to this question
