Alright so I want to get the MTM Foam Cannon for use with my Ryobi 1700psi, 1.2 gpm washer I picked up from the Depot last weekend. It comes with the 2 fittings shown, M22 threaded male, and 1/4" male quick connect.
I'd like to buy the MTM trigger gun above, for use strictly with the cannon. Why? Because I like the idea of the foam cannon being closer to my handle, and it will reserve my Ryobi trigger/wand combo for other taks. Plus at $20 the extra trigger gun is cheap.
On the trigger gun it says that:
Hose end is 3/8" female threads •Wand end is 1/4" female threads
So for the wand end, I would need a 1/4" male threaded (to gun) to 1/4" female quick connect (to cannon) to make the Cannon/Gun connection correct? Just having trouble figuring out which adapter would make it work.
PWD I emailed already twice and they are insistent that because I'm using a Ryobi consumer model that I can't switch the gun out, I can't use the MTM cannon with it, and there are no adapters that would work and I only can use Ryobi parts.
For the hose to the MTM gun above, I'm already set I believe with this adapter from AR, as it will thread into the bottom of the MTM gun and has the M22 threads for the Ryobi hose that came with my unit
Ricky Bobby
Thanks in advance for any help guys!
32 answers to this question
