ramflava Posted May 15, 2015 Share Posted May 15, 2015 Just curious what order everyone follows when detailing beyond a wash. Where do you start first? What follows? How do you make sure you get everything? Link to comment Share on other sites More sharing options...
0 landshark Posted May 15, 2015 Share Posted May 15, 2015 This http://www.adamsforums.com/topic/27911-detail-flow-chart/ TheBurninator and Kingsford 2 Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 15, 2015 Share Posted May 15, 2015 In terms of the whole process or just drying? Drying I do glass first, then paint, then wheels and finish up by wiping door jambs and areas like that. In terms of the detail process, assuming the car needs everything: Clean wheels/tires Wash Clay (while car is wet) Re-wash Dry Dress all exterior trim Paint Correcting Polish + Orange Pad Paint Finishing Polish + White Pad Finish with sealant / glaze / or wax Vinnrox250, MaverickC2 and ramflava 3 Link to comment Share on other sites More sharing options...
0 ramflava Posted May 15, 2015 Author Share Posted May 15, 2015 (edited) In terms of detailing, but I don't think I was specific enough.If we start with say....claying. Do you guys start on the hood first? Then do you go to the grill, a pillar, windshield, fenders, etc? Do work the roof 1st? Where do you go from there? How you make sure you get everything?I find myself getting a slight case of A.D.D and I may start a the hood, then work the left front fender, then to the roof. Then I might go to the doors, or maybe I'll go to the other fender. Just wondering if anyone has a routine to stay consistent. Also as far as dressing and such. Do you dress trim prior to cleaning the glass? Use in/out spray before a detail spray wipe down? I know these are broad questions, but I'd like to get people's perspectives and tips.Is wax the absolute last step after dressing? Do you follow a wax with detail spray? Edited May 15, 2015 by ramflava Link to comment Share on other sites More sharing options...
0 Beemer Posted May 15, 2015 Share Posted May 15, 2015 Claying and washing - I always work "top-down". Do the roof, glass, hood, trunk, sides, rear, front in that order. In general - save the dirtiest parts for last. I tend to do polishing and application in the same order just out of habit. ramflava 1 Link to comment Share on other sites More sharing options...
0 TheWolf Posted May 16, 2015 Share Posted May 16, 2015 Like Roger, I have also made a habit out of following the same pattern for all processes. If you follow the same routine each time for each step, then it becomes automatic and you don't have to remember where you have been or what still needs to be done. I start with the hood, then the passenger side of the windshield and the passenger side of the roof. Then to the other side, going clockwise, to do the other half of the roof and then the driver's windshield. Next, I do all the windows, starting in the same place, front passenger's side, then working my way around clockwise. Next, the upper half of the body, same starting point and same direction, then the lower half of the body, and finish with the grill and then the bumpers. Same staring point and same direction for each step. I do that pattern for the wash, then the dry. For claying, I make a small adjustment in that I do the glass last, as it is less likely to be scratched by something the clay picked up, but I still start in the same place and go the same direction. Sealing trim, same start same direction and also work high to low at each section. For polishing and waxing, I do the whole body at once, instead of top half then lower half. After washing, drying and claying, the bottom half is already clean and can be polished, sealed or waxed at the same time as the rest of that section. For your other questions, your protection layer or layers (sealant or wax or both, but sealant first) are done last. By treating the trim before sealant or wax, it helps keep the trim from being stained should you bump it with the wax applicator. There is no need to use Detail Spray after applying protection. Use the Detail Spray at your next wash as a drying agent. Junior and ramflava 2 Link to comment Share on other sites More sharing options...
0 ramflava Posted May 16, 2015 Author Share Posted May 16, 2015 Thanks TheWolf. That covers my question pretty well. Still interested in other techniques people might have. I need to organize my method of washing, drying, claying, etc. Topspin and TheWolf 2 Link to comment Share on other sites More sharing options...
0 Beemer Posted May 16, 2015 Share Posted May 16, 2015 After you do it a couple hundred times you'll develop your OWN routine. Link to comment Share on other sites More sharing options...
0 ramflava Posted May 16, 2015 Author Share Posted May 16, 2015 damn. about 70 more to go LOL Beemer 1 Link to comment Share on other sites More sharing options...
0 FRCFED Posted June 25, 2015 Share Posted June 25, 2015 (edited) When you get to polishing do you do each step on the entire car then go to the next? Or better to do it panel by panel going through all steps each time? Edited June 25, 2015 by FRCFED Link to comment Share on other sites More sharing options...
0 Beemer Posted June 25, 2015 Share Posted June 25, 2015 When you get to polishing do you do each step on the entire car then go to the next? Or better to do it panel by panel going through all steps each time? Yep. That's how I do it. But I have a garage and my car is not a daily driver. Some of us have to do it panel-by-panel due to time constraints. Do whatever works best for you. mc2hill 1 Link to comment Share on other sites More sharing options...
ramflava
10 answers to this question
