USCGRetiredJosh Posted October 8, 2016 Share Posted October 8, 2016 Does anyone use a fluid extractor like this one? I was thinking about getting one but wanted to here people thoughts, that have one or used one. https://www.amazon.com/Mityvac-7400-Liter-Fluid-Evacuator/dp/B000JFJM14 Thanks Josh Link to comment Share on other sites More sharing options...
tbarn Posted October 8, 2016 Share Posted October 8, 2016 Can't speak about that one. But a couple of guys at work have the air operated ones and they like them. Same unit basically but not mmanually operated. Link to comment Share on other sites More sharing options...
BrianT Posted October 8, 2016 Share Posted October 8, 2016 I want one! Haven't done any research though. Link to comment Share on other sites More sharing options...
blcksilv08 Posted October 8, 2016 Share Posted October 8, 2016 I have two MityVac products one for pressure bleeding a brake system and and an air powered extractor. Both work very well, just make sure you clean out well after each use. Link to comment Share on other sites More sharing options...
ocdrifter Posted October 12, 2016 Share Posted October 12, 2016 Josh I don't know if you bought your extractor yet, I recieved the Griot's one as a gift, I liked it because it came with all the attachments. It only cost a few dollars more than the one you are looking at. I've used it for brake fluid swap outs, rear differential service, power steering pump fluid exchange. It works great with little to no mess, makes life easier. Link to comment Share on other sites More sharing options...
Mantelope Posted October 14, 2016 Share Posted October 14, 2016 I haven't used that brand, but I did use the Topsider on my Golf R. https://www.amazon.com/America-5060-Topsider-Multi-Purpose-Removing/dp/B001445IZ8/ref=sr_1_1?ie=UTF8&qid=1476404429&sr=8-1&keywords=topsider+extractor After extraction I jacked up the car and pulled the drain plug. I was only able to coax a few ounces of oil out. The main disadvantage of the topsider is that you can't see through it and it has no measurement markings on it. But if you have a top mounted oil filter extraction is a nice, clean way to do an oil change. If you hit up youtube you can find plenty of extraction videos with all the different extractors. Just make sure to find one that can hold all your oil. For example, my Pontiac G8 GT held 8.8 quarts of oil, which would have required a larger extractor. Link to comment Share on other sites More sharing options...
pmichael2011 Posted October 14, 2016 Share Posted October 14, 2016 Haven't used that specific brand but use a comparable unit for doing oil changes in my outboard. Works as advertised and helps to keep things ( namely me ) clean. Link to comment Share on other sites More sharing options...
USCGRetiredJosh Posted October 14, 2016 Author Share Posted October 14, 2016 Thanks for the info everyone, I haven't gotten one yet. This is more a "want" than a need but if I have one I would use it a little bit. For my oil changes I have the quick oil drain valve on 2 of the 3 vehicles. Link to comment Share on other sites More sharing options...
ocdrifter Posted October 28, 2016 Share Posted October 28, 2016 Thanks for the info everyone, I haven't gotten one yet. This is more a "want" than a need but if I have one I would use it a little bit. For my oil changes I have the quick oil drain valve on 2 of the 3 vehicles. Hi Josh, tell me more about the quick oil drain valve, is it after market? If it is, where can I get one? Link to comment Share on other sites More sharing options...
SSilver07 Posted October 29, 2016 Share Posted October 29, 2016 That model works very well. We also have this one at work. https://www.amazon.com/dp/B007QV0966?psc=1 extracts and fills. Link to comment Share on other sites More sharing options...
