Geebee Posted November 17, 2016 Share Posted November 17, 2016 I'm pretty sure that you can, but anybody use VRT on the door and window molding trim? Work OK? I bought 100 detailing swabs on Amazon for $8.00 exactly like the ones for sale by Adam's and was going to start my rubber cleaning and detailing. Link to comment Share on other sites More sharing options...
0 chops1sc Posted November 17, 2016 Share Posted November 17, 2016 You would want to wipe the rubber down after so it doesn't run in the rain. Other than that it will work great! Link to comment Share on other sites More sharing options...
0 Geebee Posted November 17, 2016 Author Share Posted November 17, 2016 You would want to wipe the rubber down after so it doesn't run in the rain. Other than that it will work great! Chris, For the door moldings, yea that's what I'd do. However I do have rubber around the window framing that I'd need to use the swabs. As for the doors, I'd just use a mico pad and wipe it down. Thanks Link to comment Share on other sites More sharing options...
0 Beemer Posted November 17, 2016 Share Posted November 17, 2016 I had an issue with using VRT on the rubber seals on the Camaro because it left a pretty good line of "smuts" on the glass. It probably won't be an issue for most vehicles but the Camaro windows are "frameless". Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted November 17, 2016 Share Posted November 17, 2016 You are talking about the exterior correct? You should try the new Trim Coating......3 easy steps and it works great! http://adamspolishes.com/shop/specials/sub-category-1/adam-s-trim-coating-kit.html If you do go with VRT make sure you clean your trim with TRC. Rich 1 Link to comment Share on other sites More sharing options...
0 Geebee Posted November 18, 2016 Author Share Posted November 18, 2016 You are talking about the exterior correct? You should try the new Trim Coating......3 easy steps and it works great! http://adamspolishes.com/shop/specials/sub-category-1/adam-s-trim-coating-kit.html If you do go with VRT make sure you clean your trim with TRC. Chris, The trim is in pretty good shape so I don't need the Trim Coating. Just a good coat of VRT. Thanks Link to comment Share on other sites More sharing options...
0 chops1sc Posted November 18, 2016 Share Posted November 18, 2016 Chris, For the door moldings, yea that's what I'd do. However I do have rubber around the window framing that I'd need to use the swabs. As for the doors, I'd just use a mico pad and wipe it down. Thanks What I mean is, everywhere you apply the VRT you need to go back and wipe it down to help prevent streaks. It will run when it rains but wiping as much excess as you can will minimize it. Link to comment Share on other sites More sharing options...
Geebee
6 answers to this question
