OK, sorry for all the questions, but I've decided to make the plunge.
-appllicators...how many do you go through? How long, or how many sections/passes willl a side of the applicator pad last? Assume you guys rotate and use all four sides on a pad? Can you tell when it's running out of usefulness? Like does it start to get hard or crystallize on the pad?
-prep...after you've polished and have the surface ready, is there anything you should between polish and coating prep spray? Or will the prep spray remove all the oils and such leaving the surface completely clean and ready?
-boost...the boost is the same for wheel and paint coating? To same some money, I bought the paint kit and then only the single bottle of wheel coating!
-how many pads would you have at the ready for a small car and two sets of wheels?
Thanks a million guys. This has been a challenging hurdle to bring myself to this point emotionally, and I would not have made it this far without you guys as a support group!!! Hahhahahha.
galaxy
13 answers to this question
