Nathan Posted March 22, 2017 Share Posted March 22, 2017 What do you guys use to clean these? I normally use the all purpose cleaner but I was wondering if Tire and rubber cleaner would work better? Link to comment Share on other sites More sharing options...
0 Mariner Posted March 22, 2017 Share Posted March 22, 2017 APC, soapy water, and the fender brush. For me, that's satisfactory for the purpose they serve. Link to comment Share on other sites More sharing options...
0 falcaineer Posted March 22, 2017 Share Posted March 22, 2017 Then add some UCS to make them really black and disappear. Plastic ones,that is. Not the felt types. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted March 22, 2017 Share Posted March 22, 2017 I use APC to clean and then I hit them with UCS. Link to comment Share on other sites More sharing options...
0 Mariner Posted March 22, 2017 Share Posted March 22, 2017 Although last time I did a super thorough detail, I applied HGG to the plastic in my wheel wells using the dry method, and they looked great for far longer than when I used Undercarriage Spray. Just a thought. Junior and Nathan 2 Link to comment Share on other sites More sharing options...
0 Ls1transam Posted March 23, 2017 Share Posted March 23, 2017 Although last time I did a super thorough detail, I applied HGG to the plastic in my wheel wells using the dry method, and they looked great for far longer than when I used Undercarriage Spray. Just a thought. Interesting... Link to comment Share on other sites More sharing options...
0 BluedogGMC Posted March 24, 2017 Share Posted March 24, 2017 Depends on hat type you have now. My 2015 GMC Sierra has like a felt like wheel well and I just use either Car Shampoo or occasionally APC. Link to comment Share on other sites More sharing options...
0 astro-jason Posted March 24, 2017 Share Posted March 24, 2017 Mine are plastic, I use car wash soap, dry then VRT makes cleaning the next time that much easier. -Jason Link to comment Share on other sites More sharing options...
0 Junior Posted March 24, 2017 Share Posted March 24, 2017 Although last time I did a super thorough detail, I applied HGG to the plastic in my wheel wells using the dry method, and they looked great for far longer than when I used Undercarriage Spray. Just a thought. Good idea! I also saw a post where I think Dan stated the trim coating would work on the plastic wheel wells. Might help keep them cleaner and darker. Link to comment Share on other sites More sharing options...
0 Junior Posted March 24, 2017 Share Posted March 24, 2017 To the OP I believe tire and rubber cleaner would work fine on plastic wheel wells. It probably has a little more oomph. I would def try to use diluted APC. If that doesn't get you the result you desire give the Tire cleaner a shot. Link to comment Share on other sites More sharing options...
0 Lee Posted March 26, 2017 Share Posted March 26, 2017 Depends on hat type you have now. My 2015 GMC Sierra has like a felt like wheel well and I just use either Car Shampoo or occasionally APC. Same here, APC and and brush BluedogGMC 1 Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted March 26, 2017 Share Posted March 26, 2017 A pressure washer seems to do well on the felt like wheel wells. Also does well asa first pass on plastic wheel wells but the plastic really benefits from followup with a brush/sponge/towel/whatever for some agitation. Link to comment Share on other sites More sharing options...
Nathan
11 answers to this question
