rrmccabe Posted April 9 Share Posted April 9 I see they snuck another product in on is. Big fan of drying agents but not sure how I feel about this one. Will give it a try though. Doubtful I will use the cannon method but wont rule that out either. Rich Link to comment Share on other sites More sharing options...
0 RayS Posted April 9 Share Posted April 9 I found it interesting that it can be used with the Foam Cannon vs a drying aid which I think of as a mist on and wipe off. I would have liked to have given this a try at the beginning of pollen season since it gets so bad here and weekly rinses are required. Use with Foam Cannon & Pressure Washer or with Foam Gun & Hose Link to comment Share on other sites More sharing options...
0 falcaineer Posted April 10 Share Posted April 10 It's pretty good stuff! I tested it during the R&D phase and used it with the Foam Cannon, as described, and really liked the immediate hydrophobics and the shine it adds. I've actually used it a couple of times, and I think you'll like it, too. RayS 1 Link to comment Share on other sites More sharing options...
0 rrmccabe Posted April 14 Author Share Posted April 14 I will try it. I don't see myself using it in a cannon as I don't want to be be dealing with shampoo residue. I have been rinsing my cannon 'lightly' between uses. Really don't want to do more than that 😔. I would consider buying a keg and keeping it in there though and doing a final rinse cost that way. Link to comment Share on other sites More sharing options...
0 TR6speed Posted May 11 Share Posted May 11 It seems to be similar to a product that is all over FB called MAXEASY or MAXL. IT claims to apply the hydrophobic properties to the surface by simply spraying it on a wet surface then hosing it down and then dry the car. Of course, they claim that their product is better than ceramic coatings. Link to comment Share on other sites More sharing options...
rrmccabe
Rich
4 answers to this question
