After using SHR with the PC on my hood... I noticed long streaks appeared.
Wasn't sure if these were "hidden" clear coat damages and I revealed them using the SHR... or if I caused them.
Then I searched this forum and someone described Halograms as "looks almost like the contrails a jet leaves in the sky".
So... did I cause them?
Should I wait to see if they are still visible after using FMP? or should they be gone before I move on to the next step?
Couldn't get them to show up in a photo... and actually are not even sure they are halograms... considering they seem to run from the top of the hood towards the front of the car... as if something dripped/ran all the way down the front of the hood. (nothing side to side)
Then again, they do look a lot like contrails... (tiger stripes even...)...
Tried to agressively remove them in one area with the PC and more SHR... but couldn't... in other words... I tried to work on an area right in the middle... to see if I could remove part of one... but nothing happened.
I figured if I would have been able to remove part of one, I would know that it was either something I caused and/or something I could remove.
But in the end... all I did was remove more fine scratches, but the streak remained.
Brett LaCroix
12 answers to this question
