NightMare Silverado Posted June 12, 2010 Share Posted June 12, 2010 Ok so I bought the new truck but the dealer put more armorall than I've ever seen in my life on it. I used the fender brush to scrub the bed, tires, axles, fenders, pretty much the entire underside of the truck. Now my problem is it has turned the brush nasty I've tried hot water and APC I even tried scrubbing the driveway and it helped alittle but it's still just gunky and black:(. Any ideas? Link to comment Share on other sites More sharing options...
GerryC Posted June 12, 2010 Share Posted June 12, 2010 let the brush head soak overnight in water/apc. If it's still black it's probably just stained, sort of like how your tire sponges are still black after you clean them and always tell the dealer 'do not detail' ! Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 12, 2010 Author Share Posted June 12, 2010 I actually told them not to detail I already have enough armorall to remove. It was soaked in that carp before I even went in to test drive.. I'll go do that now thx. Link to comment Share on other sites More sharing options...
Kustom_FX Posted June 12, 2010 Share Posted June 12, 2010 Its not Armorall, its a polymer based stuff they use.. and its NASTY! Too the whole sample bottle of APC I had to get it just of my tires.. and it did the same thing to my brush.. I put a pot of boiling water and some APC in bucket and soaked it.. I had to do it a few times to get mine cleaner.. but it never looked right again.. Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 12, 2010 Author Share Posted June 12, 2010 Its not Armorall, its a polymer based stuff they use.. and its NASTY! Too the whole sample bottle of APC I had to get it just of my tires.. and it did the same thing to my brush.. I put a pot of boiling water and some APC in bucket and soaked it.. I had to do it a few times to get mine cleaner.. but it never looked right again.. ya my tires are 35/12 I used about half a gallon of apc and the power sprayer at the local wash to get the carp off. I let it soak overnight and although it turned the water/apc combo BLACK the brush is still nasty... looks like I'll be ordering another one and just using this one on the axles or something. owell Link to comment Share on other sites More sharing options...
Nordgrey Posted June 12, 2010 Share Posted June 12, 2010 Look something like this Stephen? Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 12, 2010 Author Share Posted June 12, 2010 EXACTLY like that....it makes me sad lol Link to comment Share on other sites More sharing options...
mc2hill Posted June 12, 2010 Share Posted June 12, 2010 Have you tried a degreaser? Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 12, 2010 Author Share Posted June 12, 2010 Have you tried a degreaser? isn't that essentially what APC is? Link to comment Share on other sites More sharing options...
JJ1o87 Posted June 12, 2010 Share Posted June 12, 2010 If apc doesn't work try simple green or greased lightning. Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 12, 2010 Share Posted June 12, 2010 let the brush head soak overnight in water/apc. If it's still black it's probably just stained, sort of like how your tire sponges are still black after you clean them and always tell the dealer 'do not detail' ! With Gerry! Link to comment Share on other sites More sharing options...
randyfox Posted June 12, 2010 Share Posted June 12, 2010 That is terrible! I would be so p!ssed. I hope some Simple Green would do the try if the APC soak didn't work. Link to comment Share on other sites More sharing options...
Kustom_FX Posted June 12, 2010 Share Posted June 12, 2010 Well I know that Castrol Super Purple is NASTY stuff, that may work as well. I use is so sparingly I have had the same gallon for 2 years! Its that brutal! I try to use Simple Green mostly, and now APC.. Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 12, 2010 Author Share Posted June 12, 2010 Thx guys. Ill probably end up ordering a new brush. Link to comment Share on other sites More sharing options...
Doug123 Posted June 12, 2010 Share Posted June 12, 2010 At least you got that gunk off of your truck! Link to comment Share on other sites More sharing options...
mc2hill Posted June 12, 2010 Share Posted June 12, 2010 isn't that essentially what APC is? I don't beleive so, but I'm not a chemist! I have had good luck cleaning my brushes with degreaser. Link to comment Share on other sites More sharing options...
BrianT Posted June 13, 2010 Share Posted June 13, 2010 What about dawn dish soap? Also try TSP. Trysodium phosphate (sp?) Link to comment Share on other sites More sharing options...
03silvss Posted June 13, 2010 Share Posted June 13, 2010 you need to use solvent to get that off. it willl take it out for sure, its the stuff you would use to clean a cement floor in a shop . Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 13, 2010 Author Share Posted June 13, 2010 you need to use solvent to get that off. it willl take it out for sure, its the stuff you would use to clean a cement floor in a shop . Got a brand name? Link to comment Share on other sites More sharing options...
Natch02 Posted June 13, 2010 Share Posted June 13, 2010 That actually gives you a reason to make another Adams order !! Link to comment Share on other sites More sharing options...
Chris@Adams Posted June 13, 2010 Share Posted June 13, 2010 Did you get your brush clean? Link to comment Share on other sites More sharing options...
Nordgrey Posted June 13, 2010 Share Posted June 13, 2010 16 hours in an APC bath didn't touch it for mine. Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 13, 2010 Author Share Posted June 13, 2010 It's been in apc soak for 2 days now and no it's scrap now. Link to comment Share on other sites More sharing options...
Sooners Posted June 13, 2010 Share Posted June 13, 2010 Mine looks like the picture that Jim posted. This was after cleaning some dirty wheel wells. However, they didn't have anything on them to begin with. It was just dirt and grime. I sprayed it down with APC, and once the water I was rinsing it with turned clear, I figured that was good enough. I've used the brush plenty of times since with no issues. Still works great. The brush is intended for a dirty job, so it's likely not going to stay looking new. Link to comment Share on other sites More sharing options...
NightMare Silverado Posted June 13, 2010 Author Share Posted June 13, 2010 Mine looks like the picture that Jim posted. This was after cleaning some dirty wheel wells. However, they didn't have anything on them to begin with. It was just dirt and grime. I sprayed it down with APC, and once the water I was rinsing it with turned clear, I figured that was good enough. I've used the brush plenty of times since with no issues. Still works great. The brush is intended for a dirty job, so it's likely not going to stay looking new. I used it on the charger 2x a week and it looked great. Im not gonna throw it out but I want one thats not nasty for the engine bay and stuff. Link to comment Share on other sites More sharing options...
