SS/ZL1 Posted April 26, 2016 Share Posted April 26, 2016 What did I do wrong? I used H2O G&G on my car over the weekend, and it left a film on the windows. I did the wet application. Its the third time I've applied it and never had his issue before. Thanks Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted April 26, 2016 Share Posted April 26, 2016 How clean was the car when applied? Link to comment Share on other sites More sharing options...
0 SS/ZL1 Posted April 26, 2016 Author Share Posted April 26, 2016 I had just washed it with Adams soap Link to comment Share on other sites More sharing options...
0 sahls01gmc Posted April 26, 2016 Share Posted April 26, 2016 How much product was applied? Almost seems like too much product, and it didn't come off properly with the dry towel. Link to comment Share on other sites More sharing options...
0 Dwhite0960 Posted April 26, 2016 Share Posted April 26, 2016 You might not of removed all the extra during the drying step. If I over apply a panel sometimes I will have to make multiple passes to buff down the streaks. Try using a spray or so less. I only spray once on a window on a full size truck and it works great, 2 sprays per doir, 3 sprays for the bedside. I think you get I'm saying try less product more is not always better. It's awesome sauce in a bottle keep playing with it. I had to find a method that worked for me, we all do things differently Link to comment Share on other sites More sharing options...
0 James__ Posted April 26, 2016 Share Posted April 26, 2016 I had this problem the first time I used H2O G&G. It happens when too much product is applied. It really doesn't take a lot of product especially once your wet application towel has a fair amount of residual product in it from previous panels. Link to comment Share on other sites More sharing options...
0 SS/ZL1 Posted April 26, 2016 Author Share Posted April 26, 2016 I my have applied to much, is there a good way to get the excess off. I used a clay bar on the windows and window cleaner and it still didn't clear up. Do I just have to let it wear off. Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted April 26, 2016 Share Posted April 26, 2016 After first wash the excess should come off- or a wipe down with the RTU Waterless Wash as it has more cleaning agents. Link to comment Share on other sites More sharing options...
0 AvsBest Posted April 26, 2016 Share Posted April 26, 2016 If all else fails APC on your windows will get rid of it. I apply 1 full spray of H2O diagonally per door basiclly. Somewhere around 10 sprays per car is enough depending on the size Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted April 26, 2016 Share Posted April 26, 2016 Absolutely love this stuff, used it on the Tundra yesterday Link to comment Share on other sites More sharing options...
0 Guest washemup Posted April 27, 2016 Share Posted April 27, 2016 (edited) If your glass already has Glass Sealant on it, the HGG will streak on it. Don't use HGG over Glass Sealant. If your going to use HGG on glass, it's always a good idea to clay the glass first if it hasn't been done in a few months, check it with a baggie, just like the paint. I actually like to use 2 damp towels with the wet HGG application. Mist the section being worked, then wring out one of the towels from the bucket, this gives the HGG time to activate with the water. If the outside temperature is such that the water on the car is drying fast, put some distilled water in a spray bottle. Mist water prior to misting HGG. The HGG needs water to work effectively and spread evenly. After you finish the section/panel, switch the wet towel out, to the unused one, leaving the used one in the bucket. Repeat process on each section/panel. This prevents the wet towel from getting clogged with too much product, making it spread less effective and evenly. If your not doing it already, be sure and use the HGG on all the black plastic trim as well, it makes it look fantastic, provides excellent UV protection, as well as limiting dust/dirt build up on it, making future washes easier and safer on your paint. If the HGG has cured on your glass, APC will remove it. A 50/50 dilution with distilled water is plenty strong enough, no need to use full strength. Edited April 27, 2016 by washemup Audog and Ricky Bobby 2 Link to comment Share on other sites More sharing options...
0 Junior Posted May 2, 2016 Share Posted May 2, 2016 Joe, I have not noticed any streaking from applying H2O on my windshield that's treated with GS. Seems like it just adds to or replenishes the hydrophobic properties of the sealant. Antv20 1 Link to comment Share on other sites More sharing options...
0 Steve_S Posted May 4, 2016 Share Posted May 4, 2016 G&G is my favorite Adam's product. I use it way more than I am suppose to, but I don't care. I love it! If you are streaking it, you are probably using too many sprays per wipe area, and or are not wiping it off good enough with a nice microfiber dry towel (after applying with damp towel). A little bit goes a long way, especially after the damp application towel has gone over a few sprayed panels. Link to comment Share on other sites More sharing options...
0 ragin_cajuns Posted May 4, 2016 Share Posted May 4, 2016 I use it on the wondows as well and have never had streaking. LIke others have said - maybe you are applying too much. I love it. Link to comment Share on other sites More sharing options...
0 Bill-V8V Posted May 4, 2016 Share Posted May 4, 2016 I gave a friend a bottle to try, he called me and thought he must be doing something wrong, it was just way too easy to use lol mc2hill and James__ 2 Link to comment Share on other sites More sharing options...
0 Junior Posted May 4, 2016 Share Posted May 4, 2016 (edited) Yes I agree fellas if you use too much you could see streaking. I have rarely seen that happen, but I got to the point I was using it every wash. I think I got a little too happy with it too! Edited May 4, 2016 by Junior Link to comment Share on other sites More sharing options...
0 Antv20 Posted May 6, 2016 Share Posted May 6, 2016 Joe, I have not noticed any streaking from applying H2O on my windshield that's treated with GS. Seems like it just adds to or replenishes the hydrophobic properties of the sealant. Same here. I apply over GS with no issues. Link to comment Share on other sites More sharing options...
SS/ZL1
Thanks
16 answers to this question
