Rollingrock321 Posted August 3, 2020 Share Posted August 3, 2020 What is the best tools to use cleaning wax that has overlapped into the plastic trim on vehicles? Link to comment Share on other sites More sharing options...
0 falcaineer Posted August 3, 2020 Share Posted August 3, 2020 Tire and Rubber Cleaner or All Purpose Cleaner will work. Next time, apply VRT to the trim before you polish (unless you're going to coat it), and wiping away any residue will be easy. 8675309'SS 1 Link to comment Share on other sites More sharing options...
0 UofAZCats Posted August 20, 2020 Share Posted August 20, 2020 On 8/3/2020 at 9:35 AM, falcaineer said: Next time, apply VRT to the trim before you polish (unless you're going to coat it), and wiping away any residue will be easy. This is one of the best tips when polishing or waxing. Much easier than applying painters tape. kaj41354 and falcaineer 2 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted August 20, 2020 Share Posted August 20, 2020 Like mentioned APC or Tire and Rubber cleaner and a lot of elbow grease. I always tape trim off when polishing so this doesn't happen. kaj41354 1 Link to comment Share on other sites More sharing options...
0 RayS Posted August 21, 2020 Share Posted August 21, 2020 I will recommend diluting the APC or using the Eco APC to help ensure that you not get any discoloring on the cheaper vehicles. As for VRT, thin coats are best to prevent it from running later, I generally us Tire and Rubber Cleaner and Painters Tape when needed. Link to comment Share on other sites More sharing options...
Rollingrock321
4 answers to this question
