mc2hill Posted November 19, 2010 Share Posted November 19, 2010 I will be using 4 jackstands this weekend to rotate the tires and clean up the wheel wells on my wife's car. I have previously only done this with 2 jackstands, but picked up another pair yesterday. Do anyone have any tips or tricks for using 4 jackstands? - how best to raise the vehicle (I'm using a dolly jack), etc. Thanks! Link to comment Share on other sites More sharing options...
Team Adam's Posted November 19, 2010 Share Posted November 19, 2010 I'm sure you already know, but work on LEVEL ground and spend plenty of time making sure the stands are resting fully on stable ground and on the frame in areas without risk of slip. The wax frame coating stuff can be slippery and even a little bit of a slant could cause one to slip. Always makes me nervous having the truck up on stands... thats a lot of weight. Link to comment Share on other sites More sharing options...
Chris@Adams Posted November 19, 2010 Share Posted November 19, 2010 I will be using 4 jackstands this weekend to rotate the tires and clean up the wheel wells on my wife's car. I have previously only done this with 2 jackstands, but picked up another pair yesterday.Do anyone have any tips or tricks for using 4 jackstands? - how best to raise the vehicle (I'm using a dolly jack), etc. Thanks! Not sure what a dolly jack is? I always use a floor jack and raise up front or back at a time, place jack stands and move to the other end. The main thing be careful! Link to comment Share on other sites More sharing options...
6spdg37s Posted November 19, 2010 Share Posted November 19, 2010 On top of the 4 jack stands I would keep your jack up on a main point of the frame as a back up ! if that makes sense... a visual may help but I dont have 1 Link to comment Share on other sites More sharing options...
IMADreamer Posted November 19, 2010 Share Posted November 19, 2010 Just use common sense. that's the best tip. Does it look safe? Does it feel safe? If not then do something different. It sounds so simple but just stopping and looking things over and thinking about it for a second can save an injury or property damage. Link to comment Share on other sites More sharing options...
mc2hill Posted November 19, 2010 Author Share Posted November 19, 2010 Not sure what a dolly jack is?I always use a floor jack and raise up front or back at a time, place jack stands and move to the other end. The main thing be careful! Yeah, a floor jack, thanks Chris. Now I want one of these! http://www.zendextool.com/rakjak/TBT2-RakJak.html Link to comment Share on other sites More sharing options...
whiterp199 Posted November 19, 2010 Share Posted November 19, 2010 I always raise the car in sections. I will raise the whole car up to the lowest level in the jackstands andthen move it up. Just pay attention and you will be fine. Link to comment Share on other sites More sharing options...
BrianT Posted November 20, 2010 Share Posted November 20, 2010 Also remember that you want to keep the jack stands as far away from each other as possible. If you put them too close to each other the car will be very very unstable. When I put my 8000lbs Ram on jack stands I lift the front first because the front end is HEAVY and the rear second. I never, never leave the truck for long without the wheels on it. If I am changing my tires around I always take all the lug nuts off each wheel, but I will leave two on each rim just in case the truck doesn't like being up in the air and falls I have it landing on the rims and not the rotors. Link to comment Share on other sites More sharing options...
crowvet Posted November 21, 2010 Share Posted November 21, 2010 A little off subject, but not really. Remember when your car is on jacks or stands be very careful when opening the doors. The body will flex and change the gaps between the fenders. We don't need any chipped paint or bent doors. Link to comment Share on other sites More sharing options...
