I posted this over on GMFULLSIZE with no luck yet so I thought I'd post here to see if anyone else has had this problem.
When I bought this truck I had to make a second trip to get the truck because it wouldn't start. The boy had his mechanic fix it. He said something got wet and had to be dried out. That was Aug of 2010. No problems until today. I detailed the engine and then washed the rest of the truck. After everything was done I cranked the truck to clean the windows. No problem this time. I did one side and was going to turn the truck around to get the other side and it would not crank. It's doing the same thing it did when I bought the truck. Everything works, it just will not engage the starter to crank.
I have pulled every connector that I can get to apart and used the air hose to dry it out. Even the big PCM module. I think that's what it is called.
When trying to crank I noticed the gear shift indicator doesn't show that the truck is in park. It has the P R N D 3 2 1 but no indication as to where the shifter is.
Anyone ever experience this? Any suggestions on how to fix it? I'd like to fix it so that I don't have to worry about going through this every time I detail the engine or drive it in the rain.
If the truck doesn't know it's in park I don't think it would engage the starter to crank. I'm calling the dealer tomorrow and hopefully I can get this fixed under some kind of recall.
InDepthAutoDetailing
Thanks
I found this:
http://www.automotix.net/autorepair/...?year_key=2005
35 answers to this question
