So I Wrecked My Vette...
Junkman2008
(The real wreck starts at post #132. This was the wreck BEFORE the wreck)
Well, I guess I more like "curbed" it but it feels like a wreck to me. :(
I was parked next to a really high curb and forgot about that when I went to leave. The damage will require fiberglass work and repainting but until I get some free time, I'll have to make it look presentable. I guess it could be worse, another drunk driver could have hit me.
Here's the damage:
So I broke out the sandpaper and knocked down a lot of clear coat. I needed to make this look as good as possible so that I would keep kicking myself every time I looked at the car. The car is so low that I had to jack it up in order to save my back. :help:
Wet sanding in progress. The damage is pretty deep.
Now I'm buffing out the damage with Severe Swirl Remover. Normally, I would have to use something more abrasive but by using a Makita rotary, SSR is strong enough to remove the aggressive wet sanding that I was doing.
I then followed that up with the Swirl & Haze Remover and Fine Machine Polish on the Flex.
The final results. The reflections of stuff on the floor makes it look like I haven't done anything! :help:
I was able to get it somewhat presentable but like I said before, this will require a repaint in order to make it perfect again. On a side not, my detail cart arrived and I was able to put it to use while I was working.
Jump to this page for the updated pictures of the 2nd wreck. :help:
  • Answers 274
  • Created
  • Last Reply
Guest Jay.B
That looks great!! And you know it was done the right way since you did the work yourself. Great Job :thumbsup:
What is being done?
Well I don't see a transmission for starters... :willy:
Now that I look closer, there's no engine either! :help:
The old girl looks beautiful, AJ. I know that it was a LOT of hard, time-consuming, labor-intensive work--but in the end very satisfying, am I right?
Hope to see you again soon!
You are correct. At least it was done to my satisfaction and I know it was done right.
I only had 1 nut left over after taking all that stuff apart. :D
