Tested some areas out today using the Flex and the micro marring went from bad to worse. Looks more like large marring now. Test spots were done on the quarter panel and hood.
- White pad, White polish, Primed the pad with a "X"
- as soon as it flashed I sprayed the pad with DS
- worked that for a few passes
Pulled the car out into the sun and this! Pulled the car back in and, added 4 drops of polish, few passes again and same results. I feel like my speed is fine, using light to mod pressure. Tried a spot on the hood and same results, micro marring turns into what looks like scratches. Pads are clean.
Plugged the PC back in and I can clean up the marring but I'm left with the micro marring. Not sure what to do! Here's some pics.
hankdog101
17 answers to this question
