livingwater Posted May 3, 2014 Share Posted May 3, 2014 I have a marine steering wheel with brush aluminum which I thought was chrome until I started wiping it down which caused scratches. What product from Adam's can I use to bring the luster back to the aluminum? I may change out the steering wheel if it doesn't clear up. Link to comment Share on other sites More sharing options...
0 2quikta Posted May 3, 2014 Share Posted May 3, 2014 Metal polish 1&2 perhaps? Link to comment Share on other sites More sharing options...
0 camaro2ssblack Posted May 3, 2014 Share Posted May 3, 2014 If it's not clear coated you can use the metal polish twins. eric@thompsonracing.us 1 Link to comment Share on other sites More sharing options...
0 Rich Posted May 3, 2014 Share Posted May 3, 2014 I'd go with the Metal Polish as well. Link to comment Share on other sites More sharing options...
0 mtnbiker326 Posted May 4, 2014 Share Posted May 4, 2014 If it is clear coated, I would recommend washing and claying it (just like your paint). Then try hand applied polishes. If they are not strong enough, gently and carefully use a PC or cyclo (with the wheel OUT of the car). Either that or use the focus pads on a drill (VERY carefully) and then finish with BG and Americana. Link to comment Share on other sites More sharing options...
0 livingwater Posted May 4, 2014 Author Share Posted May 4, 2014 Thanks... It's a Gussi-Italia The MFG name make a cheap wheel sound expensive doesn't it! Team Adam's 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted May 4, 2014 Share Posted May 4, 2014 Ron post up some pics after MP...... Link to comment Share on other sites More sharing options...
0 BRZN Posted May 12, 2014 Share Posted May 12, 2014 Is the steering wheel actually brushed aluminum, or did you turn the polished aluminum into a brushed finish by wiping it down? What did you wipe it down with? Wet sanding my be required, and that's a tedious job. If you don't know what your doing you will have a brushed finished wheel. MP #'s 1 & 2 will make the aluminum shine for sure, but may not remove many of the scratches (hence the need for sand paper), it all depends on how deep they are. I'm not so sure how you'd polish a round steering wheel with a machine as stated in post #5, I'd do it by hand. eric@thompsonracing.us 1 Link to comment Share on other sites More sharing options...
0 eric@thompsonracing.us Posted May 16, 2014 Share Posted May 16, 2014 You said it's a marine wheel. Is it on a boat? If so, bare alum pits when exposed to salt water. Should be pretty obvious if it is not cleared or protected. If you do polish it, polished alum pits worse than unpolished alum. I recommend sealing it immediately. You can even clear coat it. Be careful, being a steering wheel, you do not want to make it too slick, esp. when wet! BRZN 1 Link to comment Share on other sites More sharing options...
0 livingwater Posted June 11, 2014 Author Share Posted June 11, 2014 I only wipe it down with a paper towel think it was stainless steel. Should have known better and used my microfiber towels... Will try the metal polish later this week. Link to comment Share on other sites More sharing options...
livingwater
9 answers to this question
