tonymix17 Posted July 24, 2016 Share Posted July 24, 2016 When the VRT where is off does it leave the trim white and faded worst than prior use of it? Also for those of you who have used in an out spray same question but with the spray? Thanks Link to comment Share on other sites More sharing options...
0 chops1sc Posted July 24, 2016 Share Posted July 24, 2016 It isn't a restorer if that's what you mean. Apply it after every wash. Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted July 24, 2016 Share Posted July 24, 2016 No, after a wash or two your trim will be the same as it was before. VRT and In & Out Spray are both dressings that you would have to easily re-apply. tonymix17 1 Link to comment Share on other sites More sharing options...
0 tonymix17 Posted July 24, 2016 Author Share Posted July 24, 2016 No, after a wash or two your trim will be the same as it was before. VRT and In & Out Spray are both dressings that you would have to easily re-apply. Question for you. What would cause trim to turn severely white after product has wore off? If the trim was not initially that white before? Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted July 24, 2016 Share Posted July 24, 2016 Nothing in the products that would make your trim turn white. tonymix17 and Rich 2 Link to comment Share on other sites More sharing options...
0 chops1sc Posted July 24, 2016 Share Posted July 24, 2016 Unless you used PS on accident. What color is your VRT? Link to comment Share on other sites More sharing options...
0 BrianT Posted July 25, 2016 Share Posted July 25, 2016 Did you happen to wax the car before you put VRT on? If so the white stuff is the dried wax that you put on. Link to comment Share on other sites More sharing options...
0 BrianT Posted July 25, 2016 Share Posted July 25, 2016 To keep the trim looking good and not worry about waxing, put VRT on before you wax!! The VRT protects the trim from the wax. buffalobob920 1 Link to comment Share on other sites More sharing options...
0 tonymix17 Posted July 25, 2016 Author Share Posted July 25, 2016 To keep the trim looking good and not worry about waxing, put VRT on before you wax!! The VRT protects the trim from the wax. No i put in on my trim and wheel wells. Well see how water resistant it is! It just rained for 4 hours hard. Hopeully it doesnt come off!! Link to comment Share on other sites More sharing options...
0 Texas Moe Posted July 25, 2016 Share Posted July 25, 2016 I've made the mistake of mixing products on the trim that leave kind of a chalky white or uneven finish (I think it was VRT and then In and Out spray). Best advice I got on these forums when this happened was to use one of the brushes and some APC (or new Tire and Rubber Cleaner) to take all product off. It takes a bit of scrubbing but you can get the trim back to clean and then dress with one product. tonymix17 1 Link to comment Share on other sites More sharing options...
0 Dan@Adams Posted July 25, 2016 Share Posted July 25, 2016 No i put in on my trim and wheel wells. Well see how water resistant it is! It just rained for 4 hours hard. Hopeully it doesnt come off!! It's water resistant but not completely water proof. So if you just went through a 4-hour hard rainstorm, it may have wore off in some areas, especially if it wasn't fully dry prior to the start of the rain. The good thing is that a little product goes a long way, so you shouldn't need much if you need to reapply in some areas. tonymix17 1 Link to comment Share on other sites More sharing options...
tonymix17
10 answers to this question
